Question about Car Audio & Video
Replace 2006 pontiac g6 radio with one from a salvage yard. How do I unlock it?
    Top Expert:
  • Car Audio & ... Master
  • 79,865 Answers
Try this, many say it works
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down.
2. After doing step one and writing down the code, immediately press
the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over).
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if
you're
calling for Chevy, Pontiac, Cadillac, etc... When you here him tell
you
to press "2" for Pontiac, press 202107 and hit the # key. He'll ask
you
for the 6 digit code that you've written down. Enter that and press
the
* key. He will then give you a code, and the option to get additional
digit codes, but one should be sufficient.
4. Follow the normal procedure in your owners manual for unlocking the
radio with your new code...press the hour set button on your radio
until
you get the first two numbers of the code, then press the minute set
button until you've entered the last two numbers. Immediately press
the
AM/FM button once the correct code is entered and the code SEC or
"secured" will be displayed on the display screen. Now, just turn the
radio on, and your ready to roll.
There is an additional step you can take to remove all codes from the
radio and start from scratch by entering your own personalized 4 digit
code so that it won't get you in a pickle again! Just repeat step 4
and
you should get a display screen that reads ---. This means the code is
out, and you can now program your own code. Of course, once you
receive
the 4 digit code from the GM recorded message, just keep it in a safe
place, because you can use that same code again and again should you
have any more problems with it in the future. Good luck, and yes, it
does work.
***End Pasted Post
Posted on Sep 05, 2010
  • yadayada
    yadayada Sep 20, 2010
    why did you rate me so poorly?
Where can I get the the hard plastic that is on the back part of a driver and passenger seat in a 2005 g6?
a salvage yard would be best other Pontiac's have the same seat backs that year
Mar 30, 2013 | 2005 Pontiac G6
Light is out on my gear shift panel on a pontiac G6 2006
if its in the dash you have to remove the cluster ,, if its on the floor,, take off the deco plate around the shifter, a socket and bulb will be clipped to the side, it unplugs,, and you can get replacements at the dealer, or junk yard for pretty cheap
Aug 26, 2011 | 2006 Pontiac G6
My g6 2007 does not have the original stereo harness. Where can I buy one to install it myself so i can add a aftermarket stereo?
I would call all of the salvage yards until you are able to locate one where they have your car. Best to start as close to home as possible because you are likely going to have to go and pull it off. The Dallas County Auto Salvage yard on MacArthur will pull it for you, all you got to do is pick it up. They may mail it. I am not for sure about the mail thing though.
Feb 13, 2011 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
My radio and CD stopped playing, they think it could be the amp/speaker but the lights are getting dim only on the radio. Any idea what it could be?
Check the harness connections to the radio/cd player. If that's ok, then maybe replace the whole box from a salvage yard, if available. A 'new' one might be quite expensive compared to a salvage yard's. Check Ebay.com or do a salvage yard search.
Jan 13, 2011 | 2006 BMW 3 Series
Entire glass assembly 'fell out' of my passenger side mirror. Can I just replace the glass insert? Where can I go to get this done or can I do it myself?
call your local glasing shop... they have cut out patterns for just such issues...
Otherwise try calling the local salvage yard... and getting a used mirror?
Sep 28, 2010 | 2006 Pontiac G6
Radio stopped working properly! Pontiac G6, 2006, 6 cylinder.
The CD load/unload mechanism appears to be malfunctioning.You have to take the radio out and see if you can manually remove the disc or pick up a used radio from the scrap yard
Dec 24, 2017 | 2006 Pontiac G6
My potiac g6 died jumped it and now the radio will
The radio most likely went into lock mode as this happens when there is a power interuption as when battery goes dead. Have your dealer unlock radio as they may have to hook up to computer or give you unlock code as I donot know which model of radio you have.
Dec 25, 2009 | 2006 Pontiac G6
I have a 2006 pontiac G6. The battery died and i
I am assuming the changer is part of the radio. You try removing the negative cable from the battery and reconnecting it to see if that resets the problem, but unfortunately, the dealer is probably right - not much else you can do.
Nov 30, 2017 | 2006 Pontiac G6
GOT A NEW CAR AND DONT HAVE A MANUAL TO KNOW HOW EVERYTHING WORKS
If you will go here: http://www.gm.com/gmownercenter/pontiac/ You can get an online owner's manual for free. Or you can go here and get a paper manual. http://www.manualkingdom.com/servlet/Categories You might also find one in a auto salvage yard in the glove box of a wrecked vehicle.
Aug 08, 2009 | 2008 Pontiac G6 Sedan
Y windsheild wipers don't move. I hear the
Possible stripped gears or the gears are not making contact.  I would replace the wiper motor.  If you can, and I am not sure, you might be able to replace just the gears.  But given how new the car is, I am sure it comes as an "all in one" unit.  It is possible to seatch www.car-part.com and see if there is a salvage yard around your area that has one cheap.
Mar 03, 2009 | 2006 Pontiac G6
Car Audio & Video Logo
743 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
