Question about Fisher and Paykel Washing Machines
I have an F&P top-loading machine, about 3 years old. There is no model number on the machine fascia. The problem occurs after startup. It starts to fill with water and then it beeps. There are two lights showing, both orange. One on the long wash cycle and one on the light between the rinse light and spin light. It beeps continuously until it is turned off. This has happened a few times but after leaving it off for a while and turning it back on, it worked again. Now, it does it every time. Hoping you can help Regards Grant Leishman
  • Fisher and P... Master
  • 713 Answers
Hi Grant, just read your posting.The model number is on a sticker at the back of the machine, top left.Now the lights that come on when it is beeping will be in a row of 8 lights.Starting from the left to right which ones are lit when the machine beeps,Is it the 2nd and 5th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 05, 2010
  • 1 more comment
  • grantleishma Sep 06, 2010
    The model number is MW512. The two lights that come on with the continuous beeping are the 1st and the 7th light. It begins to fill with water for about 5 - 10 seconds before this happens.
  • luisa_sgro Sep 06, 2010
    Hi Grant just read your last posting.The ERROR CODE on your machine is called SINGLE ROTOR POSITION SENSOR ERROR.This means either the wiring to the rotor sensor, which is attached to your motor, is faulty or the rotor position is faulty or your motor controller is faulty.To test the rotor sensor unfortunately you need a RPS tester.If you have or can borrow an electrical test meter I can help you test the wiring but I am sorry I can not help you test the rotor sensor without an RPS tester.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
  • Sam Mitchell Jul 28, 2017
    This has happened to mine too. So what was the solution?
Where do you find the make and model number on a 10 year old kenmore washer so i konw what part to buy?
See the following:
Model numbers for Sears / Whirlpool machines usually start with the numbers 110.
Most top load washers will have the full model number visible when you lift the lid and look toward the back of the machine.
Aug 05, 2010 | Washing Machines
Problem with my LG washing machine WF-S7012DN model - 7 yrs old. Since yesterday, the wash/m starts to wash takes a turn or two and them stops with alarms on and flashing, (first time problem with my...
there is a magnet controlled switch in the top cover lid and the probable cause the magnet is missing.
The best alternative is just keep a good magnet on the top of lid & slowly move the magnet horizontally.At one point the BEEP stops & machine starts to function.
Jun 03, 2010 | LG WFT1071TP Top Load Washer
This is a known problem with this model. Call 800-847-9083 and give them the model and serial number to see if your unit is covered by a recall on the control board. I called a few weeks ago and they sent the part and a tech to install it for free on my 3 year old machine.
Apr 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer - Machine is 5.5 years old just started displaying the "dc" error message. Move clothes around but takes 3 times plus to get the load to finish. Serviceman was not...
Hello weirc215
Thank you for posting your model many folks post non FAV6800A/FAV9800A issues in this forum.
It is a Clutch issue. The One-Way Roller Clutches in the hub of the clutch are not locking up in Spin cycle. Most times you can get away with a low cost Clutch Maintenance.
See my Clutch Maintenance Post for the details….. Clutch Fix Post It’s posted under my old forum nickname dh1200s.
If you or someone you know have very basic mechanical skills you can do this and save your machine and you $300+ over calling in a repair company that may not know what the issue is.
I will help you or whoever will try to do this. Can you give me the 1st two digits serial number located here?
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission.
Jan 30, 2010 | GE WDSR2080D Top Load Washer
Bought second hand machine. works well,however makes noise from underside machine while in operation. and bangs signifigantly when it shuts down. It's a whirlpool unit. unsure of model number. about 3/4...
This sounds like the brake is engaging to stop it from spinning. You can find the model number under the lid at the rear of the lit on the maching. I am assuming this is a top load model.
Jan 04, 2010 | Whirlpool Washing Machines
Error number 5
if you look on the back of the machine you will find 3 screws securing the top of the machine. the top will then slide back and lift off. the tech sheet should be inside and will explain the fault code
Jan 31, 2009 | Washing Machines
Whirlpool washer does not start after fill with water
It sounds like the washer tub is off balanced. When it is, it will usually not start. Underneath the washer, there are 3 or 4 bolts or nuts, depending on your washer model, that hold the washer to these balance springs. make sure that the bolts or nuts are tight or secure. If this doesn't help, get on a website called They usually will help with home repairs.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
166 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
