Question about Landice L7 LTd Pro Sports Trainer Treadmill
I have just purchased a Landice P 7 Pro Trainer and notice that a light is constantly on in the front part of the machine where the motor is located. Is this normal? Also, I am having difficulty inputting weight and grade before I start the various programs. The accompanying manual is for the birds in its explanation. thanks, Mark
  • 79 Answers
If no error number as "L5" should work well, with respect to the LED light is normal if you have more questions please send me a E-mail to cardiotech_me@hotmail.com I have the technical manuals, I will be going up soon FixYa.com
Posted on Sep 07, 2010
How do I replace the speed sensor on the Landice L9 pro sports cardio trainer?
the speed sensor is in the front drive wheel. it is a sensor located on the left-hand side you will see a wire going to the sensor. then a magnet is on the wheel and when it passes by you get your speed.
Oct 16, 2016 | Landice Exercise & Fitness
My landice L7 pro Trainer is not working when you press the start button the motor jolts a little the L5 shows is the display screen
It needs a lower board, does your machine have a life time warranty? Part should be covered just not the labor.
Apr 02, 2015 | Landice Exercise & Fitness
With the L7 plugged in, and after pressing the start button, nothing lights up and the belt does not move.
looking for a qualified technician to check the connectors on the lower board specifically where the motor wires connected.
this part of the lower board overheats and sometimes there are false contact.
Aug 25, 2010 | Landice L7 LTd Pro Sports Trainer...
Overspeed
Your speed sensor is not working properly this part is located under the motor shroud and on top of drive motor it is attached to a bracket with 2 bolts. Unplug the unit and remove motor shroud see if you can adjust it first by loosen the 2 nuts and moving the sensor forward without making contact to the flywheel, then tightened the nuts up. Plug the unit into the outlet, start the unit, if you still have the overspeed then replacement of the sensor is needed. Call Landice Directly they will ask for model and serial number and they will the new sensor.
Jun 28, 2010 | Landice L7 LTd Pro Sports Trainer...
Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
Belt does not move panel lights up
Does your L7 have error code that looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Feb 07, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
Landice treadmill
You may want to take off you head board and check all the connection. this is not hard to do. Also when you in there check you cable connection. can you do this?
Jan 10, 2009 | Landice Pro Sport Trainer Treadmill
Landice L7 LTd Pro Sports Trainer Treadmill Logo
130 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Sportsmith LLC
Sportsmith LLC
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
