Question about Toshiba Satellite P100 Notebook
I am having problems with my Toshiba Satellite P100's display it only started happening when i installed windows 7 onto it the problem is that i am getting a heap of pixels in the wrong color and the number and position of the pixels depends on the image on the screen any help
  • A1dan9 Sep 06, 2010
    i have tried that but the problem is still there
    President:
  • 2,571 Answers
You could try using the vista display driver from toshiba, or there is a driver for your Geforce go 7600 chip from nvidia here http://www.nvidia.co.uk/object/geforce_notebook_winvista_win7_179.48_beta_uk.html
Posted on Sep 05, 2010
  • Roy
    Roy Sep 07, 2010
    Thanks for the feedback, I managed to find win 7 drivers for your laptops chipset, some people are unbelievable
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
How to check out or look for problems with the lcd monitor on toshiba satellite p100
The internal screen is faulty. Check the inverter first. (under the display).
Jan 20, 2013 | Toshiba Satellite P100-102 P100-103...
HI I Have a toshiba p100 laptop. i have had to re-install using recovery disc, the computer would start then shut down. with computer connected to external monitor it runs throught start up then ' say's...
I have the same computer. Recently, it started shutting down without noticed after an hour use, sometime earlier after heavy use. I did a Google search and find out that some Toshiba has overheating problem, and it was recommended to clean it the heat sink. If that is dirty the heat can not escape. I used a vacuum cleaner to **** out the dirt. It worked after so far.
A year ago, I had an other problem, I upgraded the memory, I used the Vista memory test. It did not reported errors. It became unstable, it would run for weeks without problem when for no reason would give file read errors, and all kind of problems,... So I created a bootable USB drive with memtes on it. My Toshiba booted to a linux op. and run the "memtest". It reported error on my newly installed memory. ... I used the recovery disk to have a clean start.
Also, during those times and sometime after, I've got those message, your window can be start, do you want to rollback to a previous point. Many time that message can be ignored, and just persist to start Window normally. Eventually it will, (if you know that your memory is working). I hope this helped.
Sep 27, 2010 | Toshiba Satellite P100 Notebook
Toshiba Satellite A135 S2276 with windows 7 Ultimate
  • Hi, when ever there is a [? mark] next to any of the Components in the "Device Manager" there is a {Problem!} The only solution is to "Uninstall the Hardware Device" and reinstall it. Next your going to have to "Update the Drivers," and restart the computer afterwards. To "reinstall" the "Display Drivers," do the following; open the Start Menu, in the [Start Search Window], Type: toshiba, next scroll to find the [Toshiba Application Installer]. Open the window and "Install" the Display Driver. Restart the Computer after all changes are complete. "Let me know how things worked out for you by giving a "Helpful Rating," and thanks for using Fix' Ya.
Jul 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Audio driver installation problems
Did you do the install by clicking on the setup file?
The other way of installing is to do from the Device Manager and click on Update drive and direct it to the location where the driver file is stored on your computer.
If that doesn't work, get it to search the driver off the Internet.
May 16, 2009 | Toshiba Satellite P100 Notebook
Startup display problem P100 PSPA3E
Hi, ok clearly for the symptom of what describes modal to his portable , I understand that the fault of his equipment comes from the card of video, which not this on board but it is separated, if the problem that he presents also happens for the VGA port and for the DVI port, this indicates that the problem that his equipment presents into in the system board.
Dec 06, 2008 | Toshiba Satellite P100 Notebook
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Jan 11, 2008 | Toshiba Satellite P105-S6104 Notebook
Open Questions:
Toshiba Satellite P100 Notebook Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
