We have a Brother MFC 5840CN. Yellow ink is almost constantly near empty. We fill up at least once a week.
  • 832 Answers
Be carefull!
It might be that the cart holder is defective:
the ink is beneath the holder and will stain your funiture!
You have to open the printer and have to replace the cart holder!
Posted on May 12, 2008
MY MF210C IS ASKING FOR YELLOW INK. I AM ONLY
Your printer mixes colors even with black, you must have ink in all carts.
Aug 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
Can't send fax because of message: Ink Empty Black-Replace Ink
No, the machine needs to have all cartridges installed to perform all actions, including fax and scanner functions.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Ink level status on black ink is not accurate
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
MFC-5840CN "unable to clean" and "machine code 50"
you have to fix the encoder strip into right position within the ph carrier! do push the head left/right to see if there are waves infront of it. if so, fix the strip into position!
BTW:
If you refill your carts use 2ml glycerol (from drugstore) with 10ml dye-ink: mix well before refilling. For bk use 1,5ml glycerol with 20ml bk dye-ink.
The glycerol prefents the ph/nozzels and tubesystem from drying up!
Apr 21, 2008 | Brother MFC-5840CN All-In-One InkJet...
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
73 people viewed this question
jasbo
jasbo
