2005 Mazda 6 Logo
Posted on Sep 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 mazda6 wont start new alternator, battery, and starter
Johnny Brown
Level 3:
  • Mazda Master 5,763 Answers
  • Posted on Sep 05, 2010
Johnny    Brown
Mazda Master
Level 3:
Answers
5763
Questions
0
Helped
3161060
Points
20432
Have you tried a diffrent key, these keys have chips in them without a good reabable chip it will not start, i would first have the computer scanned for any stored codes as when theres a problem the computer picks it up and stores codes, these codes will help by telling you where the problem is and with some checking you can find the core of the problem, i,m not sure whats happening when you try to start it but from the parts you listed i guess it doesnt do anything when you turn the key, the engine doesnt spins at all and try to start. i would try key first and then scan for codes. hope this helps.
Why wont myMazda 6 will start?
try this its a common problem over time. http://www.underhoodservice.com/no-start-no-crank-mazda6-engine/
My 2005 dodge ram 1500 wont start and the etc light and the check engine light both stay on
Check all the electrical connections . grounds and to starter. One of them are bad or the new starter crapped out on you. Remember just because it is new doesn't mean it is good. I have got new items that were junk out of the box.
Wont start
Elaborate please. Does the starter turn the engine over? Does the start not even turn?
New battery new alternator wont start ?
I'd check for bad or corroded contacts/cables from battery to starter (If your vehicle is older than 14 years). If that looks good I'd be suspicious of the solenoid in your starter sticking(will probable need a new starter).
2answers
Mazda 6 2003. Battery Light. I have been getting Battery light on my Mazda 6. After 10 minutes of driving i will get all lights on Air Bag, Handbrake, Dimmers, engine light..possibly all light on the...
Hi, unfortunately your voltage regulator is controlled by the PCM. If the 120 amp charge fuse is good and the alternator is good; then the PCM is probably bad, as your mechanic is suggesting.
2answers
2005 jeep gc wont start. replaced fuel pump,replaced battery, run for two weekes, wont start but it click clicks
will it start with a jump? check battery for full charge, maybe alternator is not charging, check battery connections all the way down to starter, check selonoid by cross jumping terminals to engage starter.
I have 91 4 runner new battery & alternator & new starter
did you check all the fuses and the main fuse under the bonnet try to give thr starter a few taps with hammer not hard if starts then it is brushes in starter ,does light come on on dash if you put key in on position
3helpful
2answers
Son has a 2005 Nisssan Altima and Hear clicking sound.
Most likely the alternator,chech for loose connections at the alternator first, if you have access to a voltmeter you can easily check this.Get the car started and place the leads to the battery terminals,if the alternator is good you should get about 14.8 v at idle and it will go as high as 15.5v to 16v as you rev the engine up.Anything between 12v and 14v at idle indicates a weak or not operating alternator.If you get a good reading run it for a bit and then see if it will start again,if it wont start check the battery cables(especially the negative) for corrosion or loose connections,look for cuts or tears in the insulation or a bulge in the cable wich will indicate corrosion under the insulation.If everything else checks out good and it still won't start then you'll need to look towards the starter.
2answers
2005 Honda Civic wont start. Just makes a clicking sound
This sounds like a starter problem, does it click when you hit the key? are the battery cables ok, not corroded?
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
