Question about Gateway FPD2275W LCD Monitor
Moniter stays on only breifly bout 1 minute & then shuts off.
  • 11,361 Answers
Look for bad caps in the power supply as shown here:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Be real careful when separating the front bezel or you will break the ribbon cable.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 06, 2010
2007 vulcan 1600 classic wont stay running
i rekon when ya changed the tank over it had rust in it and has contaminated yer fuel lines, pump and carby with bits o rust. So rip off the tank, lines,pump and carby and give em all a good clean, reassemble and yer all good to go.
Nov 05, 2017 | Motorcycles
Would like to know why the gas heater won't stay on. Lights for a bout 5 minutes then shuts off.
Is the fan running after furnace light because there might be an issue with the blower .if blower doesn't come on unit would shut off on a safety switch called a high pressure switch
Jun 03, 2017 | Heating & Cooling
My moniter wont stay on
Have you gone into display settings to make sure that your screensaver is not set to something like 1 minute away.
Or go into Power Settings and make sure that your "shut display off" is not set to something very short either.
Nov 23, 2011 | HP Computers & Internet
Otiplex 760 will power up breifly and shut off as if the thing was unplugged , sometimes will stay running for a few minutes and sometimes will shut off immediatly. I cleaned the old heat element compound...
1. Try blowing the dust on the motherboard, if any hard dust is present, use soft brush to clear it.
2. Again remove the Heatsink on the processor, completely clear the compound using soft cloth, There should not be any hard particles or dust left, apply heat sink compound on both the heat sink side and on the processor, put back the heat sink and fan.
3. Check whether the power button on the cabinet is not struck and functioning if possible try to replace the button.
4. Blow the dust even from SMPS or try with another if handy.
Sep 05, 2010 | Computers & Internet
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Sony KDF-E50A10 Shuts off and on every 1- 2 mintues
From what it seems in your question... the problem has already went away... However, I actually know about this. There is a fuse inside the tv near the power button called B-3a... If you replace that fuse it should help fix permanently
Dec 17, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Gateway FPD2275W LCD Monitor Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
