Question about Xerox Phaser 8400 Laser Printer
Persistent white stripes
My Xerox 8400 has the "white stripe" problem. Have tried the built in cleaning routines and the 8400_jetfix program. Have e-mailed Xerox service and they told me to buy a new printer. This printer has only produced 4200 copies and used only genuine Xerox inkstix.
Xeros thinks it needs a new print head which according to Xerox costs more that the printer.
Is there aaanother solutuion? Can the print head be cleaned of whatever is clogging it?
  • 3 more comments
  • gsl01 May 12, 2008
    The 8400 is a solid ink printer and uses inkstix. the ink is melted in the machine. The machine has an automated process for cleaning the heads to eliminate "white stripes" which I used many times. Also shuting down the fprinter makes it dump the melted ink which can help (it didn't) and uses a lot of expensive ink. Xerox also has a cleaning routine that you download to the printer called 8400_jetfix with a separate program for each color. That didn't work either, just made the problem worse.
    -jetfix
    They run vertically down the page and no they don't. When I used 8400_jetfix for black, the program prints 5 pages that are supposed to be all black. For me, the first page was covered with white stripes of missing ink. each page got fwhiter and whiter until the last page is just a couple of black stripes. Leave the printer set for a while and it recovers a little. overnite it can recover to where i can maybe print a page or two and be able to read it.
    The "white stripes" are predominently in black areas. and that conforms with the 4800_jetfix program results which I described above for the black color, for the other colors (which are run separately with a program for each color) the first page is solid color with no or little stripping. second through fifth pages start to show increaing number of stripes.
    The paper count is 4219. I did wipe off themaintenance unit wiper blade. What is the CWP aaay? Note: the stripes are not accross all colors on a page, but mainly in dark or black areas. They are what the printer manual call lightr stripes but are not "predominant' light stripes as might be caused by dirt build up. The printing of pages of solid colors is what 8400_jetfix does, and I've tried that.
  • gsl01 May 13, 2008
    gsl@wideopenwest.com
    President:
  • 2,712 Answers
In my honest opinion, it would be worth your while to invest in a new printer (perhaps something cheaper, in terms of overheads and maintenance costs)..
Posted on May 12, 2008
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    It could be a problem with the heating unit that "melts" the ink.
  • Swilin Sampson
    Remember that you have to leave the printer on for at least 6 minutes before using it for the warm up mechanism to complete. Also if you do not use the printer every few days, the ink can crystallize. And it is also recommended that you leave the printer continuously on for the same afore-mentioned reasons...
  • Swilin Sampson
    Here are some suggestions I found on another website:
    Check the maintenence count. May be expired.Clean the edges of the
    wiping blade. The CWP assy. may be caked up on the edges, and does not
    seal to the printhead.
    Check the cleaning blade under the top cover.
    Print 10-15 pages of solid colors to clear up clogged jets.
  • Swilin Sampson
    Swilin Sampson May 13, 2008
    CWP = Cap Wipe Purge. It could be misaligned, and this could cause the stripes.
    You should have a Eliminate Light Stripes process. Try running that as well..Also try emptying the maintenance tray.
    You may need the services of a Xerox technician or a qualified pro do get all these things done..
    Sergeant:
    Champion:
  • 209 Answers
Hmm, I'll try to put in my 2 cents...
Ussually when the head gets clogged they throw them out but since this is expensive.
Try running the self-cleaning process a couple times.
Otherwise try this:
"I discovered that isopropyl alcohol (I bought a bottle of 91% alcohol at the drugstore for ~$3) is a great solvent for this sort of dried ink. There were those that recommended that I take an old, discarded ink jet cartridge, open it, clean it out with the alcohol, fill it back up with alcohol, reseal it, and place it in the printer for a few runs through the printer's self-cleaning method. This proved to be a rather messy endeavor indeed, so I followed a bit of less-agressive advice.
I simply removed the black print cartridge from the printer and dropped 7-10 drops of alcohol down in the ink-recepticle area where the ink cartridge normally sits (there should be a little hole down in there where the ink actually flows from the cartridge into the head), replaced the ink cartridge, and ran a few sessions of the printers head-cleaning routine. It took quite a few cleaning sessions (probably 15-20) with a few pages of text prints thrown in there just to try and move some ink, before it cleared up"
and to give credit where credit is due, it's from this website: http://www.weeno.com/art/0899/140.shtml
Well, try that and tell me what you turn up with.
Good luck.
  • Simon Zwaan
    Simon Zwaan May 14, 2008
    Did you try the cleaning thing ?
    Maybe try that before you get a new one.
    Well, thats about all my knowledge on printers.
    Good luck.
    Scholar:
  • 103 Answers
Are they always in the same place on the page or do they appear random? If it is hard to tell, set the pages next to each other. This might help me troubleshoot it.
    President:
  • 2,072 Answers
You said you have tried the jet fix. Does that mean you have tried in particular running the pattern and trying to substitute the suspect jets? I am assuming you have.
The wiper could blade could have ink built up on it, or the maintenance kit could be contaminated.
One other thing when reading your problem. Normally you do not get a white strip. When you are referring to the strip, is it just lighter, as if one color is missing, or is it totally blank? Totally blank would unlikely be a print head. If you are referring to just a lighter area, then yes that is the problem.
Retail that is a $750 part.
I know of no way to clean the print head. What you do when you run a remove light stripes procedure is empty the ink form the print head, and one of the odd noises you hear is a compressor blowing air through the ports clearing the jets.
  • Rick Kasper May 13, 2008
    If it is the light stripes, and you really have done all you can minus replacing the print head.
    Send me your E-mail address and lets see what we can come up with for a print head price wise.
    If I am not installing it, I can sell it to you for less.
    I work on those printers daily.
    What you have done is every proper step to resolve that short of replacing the print head.
    Wish there was more to offer, for whatever reason those print heads will fail.
    The phaser toner products, dry ink, have a new technology in ink that produces images better than the solid ink. And no print head, they are standard drum and toner units.
    Let me know, I will help you however I can.
On my Xerox Phaser 8560 DN I keep running the light stripes test to fix the weak/broken jets, only to have another stripe appear in another spot! It's like playing ink-head whack-a-mole. Needless to...
Have you tried using the jet substitution instead of cleaning every time. We used to do that till we had 5 or 6 weak jets then run the cleaning and if they have all recovered turn off the jet substitution..
Mar 28, 2017 | Xerox Phaser 8560DN Laser Printer
I have light vertical stripes on a dark picture and dark stripes on lighter colored pirctures. I have cleaned the head about 15 times and it is worse now than before. I am wasting ink and getting nowhere....
Have you checked the maintenance kit? Is the white roller badly contaminated? The mylar blade dirty?
If that is ok, then you may have a bad print head.
Mar 10, 2010 | Xerox Phaser 8400 Laser Printer
Black stripe and white stripe on copies
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Feb 16, 2009 | Sharp AL 1631 Copier
Persistent Light Stripes
Some thoughts are these. 1. Is your maintenance kit new and in good shape. 2 There is a remote possibility that the cleaning blade has buildup on it. But most of the time in that situation the print head is bad. Moreso likely if you use non Xerox ink sticks.
Feb 05, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Clean an 8400
Replace the maintenace kit and then in the menus run eliminate light stripes and eliminate smears.
There really isnt much else to do.
What you do when you run the light stripes and smears modes the machine removes all the ink from the print head, turns on a compressor and blows out the jets on the print head.
There really isn't a "cleaning " procedure as with a laser printer. If the maintenance kit is good, it pretty much maintanes itself.
Jan 06, 2009 | Xerox Phaser 8400 Laser Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Xerox 8400 light printing
No, If one lamp goes out they both will not function. They do not have anything to do with print quality.
You may have a bad maintenance kit. but more than likely you have a bad print head.
Run the cleaning , eliminate stripes and eliminate smears modes. But more than likely the print head is bad. I would say a bad print head is about a 95 percent chance of causing your problem.
The halogen lamps only heat the drum, and if one was bad the machine would fault out with a 15,004 code.
Oct 11, 2008 | Xerox Phaser 8400 Laser Printer
I have a phaser 8400 banding problem. Actually reverse banding. It is ligher ink vertically along left margin and an inch from right margin. Is this a drum problem? It notes I am low on ink and have only...
nope its not a drum problem, That drum never goes bad. You are having a problem with some blocked jets in the print head.
You can scroll through your menu to troubleshooting and there are cleaning modes to eliminate light stripes and to eliminate smears.
Run the eliminate light stripes maybe 2 or 3 times. If that doesn't work, then try the jet substitution mode.
That is better described at Xerox.com, click support, then enter phaser 8400 in the search box, click support again and then enter
"jet" in that search and follow the directions.
If those do not work then your print head is most likely bad. Thats more likely if you have used non xerox ink sticks.Being low on ink should only give you a message that its low.
Aug 25, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 light stripes
Your print head is in ned of replacement.
If you have done all you have, not much more that can be done.
You can try running that eliminate stripes a few times, and also in that area try the Jet Substitution, and see if you can open new jets to bypass the blocked ones.
after that, your print head would need to be replaced.
Wish I had a better and cheaper answer.
Xerox Phaser 8400 Laser Printer Logo
182 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
