Question about Rain Recording LiveBook L4 Notebook
My laptop wont go on - Rain Recording LiveBook L4 Notebook
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 20, 2010
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Laptop wont come on
It is damaged. The whole replacement NX6110 (good working laptop) is available on eBay.com for $50 + shipping, so I think it is easier and cheaper to buy a replacement laptop than to fix this laptop.
Mar 01, 2014 | HP Compaq nx6110 PC Laptop
Laptop wont charge. light does not come on
It is most likely a bad battery. Also, if you can find another charger like the one you have you could check to see if the charger itself is the problem. In my experience, the battery is the likely culprit.
Sep 27, 2012 | Samsung Rv-511-a01 Notebook
FUJITSU SIEMENS S6010 WONT TURN ON, HELP!!!!
Hi, I have alot of Motherboards for that Laptop. Maybe a New Motherboard Needed. CPU May have Burned out?
Email: microxtremecomputers@live.co.uk
Jan 28, 2010 | Fujitsu Siemens Computers & Internet
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
Laptop wont charge at all, or turn on
hey friend . .
this indicates that your battery is finished just go and buy new or
the battery need a repair . . . its charged is over . .
Oct 06, 2009 | Computers & Internet
The on button wont switch on my laptop
Please try following DIY
1.Remove the battery and press the power button for one minute.
2.again plug in the battery and try to start.
3.open the RAM chamber and refix the RAMs.
Jul 14, 2009 | HP Pavilion dv6000t Notebook
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
Rain Recording LiveBook L4 Notebook Logo
107 people viewed this question
Top Rain Recording Computers & Internet Experts
David Payne
David Payne
Are you a Rain Recording Computer and Internet Expert? Answer questions, earn points and help others
