Question about Zanussi F1245W Front Load Washer
Zanussi Aquacycle 1200 Model F1245W wont drain. I cleaned filter. Removed pump and tested if off line and it spins so I am presuming that the pump is not getting power. Is this a PCB/Timer Main Board fault and if so how do I replace this part.
  • 2 more comments
  • eugene_mcmah Sep 06, 2010
    I will check the wiring to the pump for continuity. Do you know what pins on the PCB/Timer feed the Pump. If the wiring is Ok, what do you recommend next and can you tell me how do I remove the timer know and the PCB/Timer Module.
    Rgds, Eugene
    Type error in my last comment, meant to say remove Timer knob.
    Rgds, Eugene
  • eugene_mcmah Sep 07, 2010
    I checked the wiring coming from the PCB/Timer to the Pump and all is well. If you do not think it is a timer problem what do you think it is. In my opinion it can be nothing else. Rgds and thanks
  • eugene_mcmah Sep 08, 2010
    That's not much help to me telling me it might be the timer. I knew that from the start. I am trying to find out how do I know for definite it is the timer.
  • 5,081 Answers
We cannot say if the timer is problem without inspecting the wiring to the pump.
Consider an power supply wire to the pump is broken , then even if the timer is good it wont get power.
Posted on Sep 06, 2010
  • 2 more comments
  • INDIRA KUMAR
    INDIRA KUMAR Sep 06, 2010
    What do you mean by removing the timer knob?Do you want to replace the timer circuit?
  • INDIRA KUMAR
    I donot think the timer is faulty..
  • INDIRA KUMAR
    INDIRA KUMAR Sep 07, 2010
    If you have checked all the wiring and everything is fine then there are possibilities of having problem with the timer.
  • INDIRA KUMAR
    INDIRA KUMAR Sep 09, 2010
The washing machine does not evacuate water and does not go in spin cycle.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Zanussi F1245W Front Load Washer
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Jan 09, 2010 | Electrolux Washing Machines
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Oct 06, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi Aquacycle F 1045W doesn't drain
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Zanussi IZ12 Front Load Washer
Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Jun 29, 2008 | Zanussi F1245W Front Load Washer
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi F1245W Front Load Washer Logo
394 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
