Question about Brother MF-C8840D Remanufactured Laser Flatbed Multi-Function Center (MFC8840D, MFC8840-D, MF-C8840-... Printer
Reset drum I need to reset the drum.
    Problem Solver:
  • 6 Answers
How do I reset a drum from user mode?
This is simple. You can't. Manufacturers make their money from consumables. They don't want you to be able to reset anything to get more life. The drums have internal fuses that blow when put in the machine, that's how they reset the counts. Sorry.
Apr 25, 2015 | OKI C9650HDN Led Printer
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
HOW TO REMOVE DRUM ERROR IN BROTHER HL2140 PRINTER
Need to replace drum and reset the counter
(Essentially the cartridge/drum unit should not be in the printer when you reset it)
1) Open front door
2) Remove the cartridge/drum unit
3) Hold down front button until all lights come on
4) Put cartridge/drum unit back in
5) Close the front door
The Drum life should be reset.
Jul 07, 2011 | Brother HL 2140 Laser Printer
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Sep 29, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Replace drum, still says replace the drum and now it won't print.
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
May 12, 2010 | Brother MFC-9440CN Laser Printer
Okipage 8w print drum
Reset the Drum Count:
Open the Status Monitor.
Click Printer Setup tab.
Click on Printer Menu button
Click the Maintenance tab
Click on the Drum Counter Reset button.
May 15, 2009 | OKIPAGE 6w Led Printer
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Brother MF-C8840D Remanufactured Laser Flatbed Multi-Function Center (MFC8840D, MFC8840-D, MF-C8840-... Printer Logo
95 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
