Question about Linksys Wireless-G WRT54G Router
My WRT54G wireless router does not connect to our laptops. The (4) wired ports work fine. What am I doing wrong?
  • Linksys Master
  • 7,733 Answers
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Posted on Oct 29, 2010
Hi my router is showing internet connection and the wlan is green or the green light is on. in the numbers 1-4 there is no lights on. I don't know if this is the problem or not but i have no connection...
The lights 1-4 refer to the wired LAN ports, if none of these are on then there are no LAN cable connected to these ports.
Try rebooting (power off then power on) the router first then reboot your laptop to see if the wireless connection is re-established.
If not, check the router's wireless settings ie. SSID, encryption etc., and check the wireless card settings in the laptop - these settings must be the same for the laptop to connect to the router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
I can't connect my lap top or any device to the router by cable only wireless can connect it seems that the 4 ports doesn't work
I would try another ethernet cable, it is very rare that all 4 wired ports are dead unless it was damaged in a power surge.
Oct 21, 2010 | Linksys Wireless-G WRT54G Router
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Router will not work wireless after switch from DSL to cable
You can go to 192.168.1.1
Enter the default username(leave it blank) and password(admin) and enter the router page
Under setup--> basic setup you can configure your ISP settings
Under wireless you can configure wireless username password etc
If still unable to connect wireless mention the operating system
Jan 29, 2010 | Linksys Wireless-G WRT54G Router
My wireless router with ports works fine with hard wire connect. I can' t get my laptop to connect wireless. Reset unit and all. can u help Lynkys, wrt -G ver. 6 Used to work fine. Cisco, says by another...
It can be fixed most likely unless its just an old unit that has burnt out. Try reinstalling the software that came with it and rebooting your system. If that doesn't work search for discussion in wireless router discussion forums.
Nov 09, 2009 | Linksys Wireless-G WRT54G Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
WRT54G Router Hookup
All you need to do is connect the modem to the router. From the router, you will want a computer connected to it so you can configure your wireless network.
May 28, 2008 | Linksys Wireless-G WRT54G Router
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Ethernet problem
1. Restart your router
2. Restart your computer
3. Check your ethernet cable. Try another one if possible
4. Try to connect to another port on your router
10. Your port on your PC is dead(Heat by lightening)
11. Your router is bad
Feb 28, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
99 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
