Question about Kenmore 47783 Electric Single Oven
Kenmore 47783 w/ F11 code, a locked door and food inside
How do I get the door open and my food out. I tried calling kenmore. They want to charge me 65 bucks, be out in a day or two and not guarantee the repair. Please help. I am hungry.
  • roeja May 13, 2008
    Our oven door is lock, push several buttons to get door unlock. Very unsuccessful. Help please
  • gettie Jul 04, 2008
    I can not unlocky oven door. I don't see a code any where. HELP!!!!
Get off the FixYa web site (a total scam).
Posted on May 13, 2008
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
What does f2 mean?
It is a oven temp too high code...check thrmeostat connection if ok, try unplugging or disconnecting power aprox. 1 min try again if F2 comes up again need to replace sensor
Feb 11, 2009 | Kenmore 47783 Electric Single Oven
Kenmore Electric Range Slide in....beeping while not in use
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
Jan 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked door light on but not, won't bake
Check your breakers and also your wiring. Try to turn off the breakers for about 10-15 seconds. Your board inside the control panel may be bad since you are getting mixed signals.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
Kenmore door locked
Try pushing and holding the door shut. Then moderately tap on the door where the latch is and it may come loose. Usually it is mechanical and not electrical here. Could also be if you have a self cleaner on it, that it is reading that you are cleaning the oven. If the first thing does not work, then turn off your breaker for about 15 seconds and then back on. Sometimes it may reset itself and put it back in working order.
Nov 04, 2008 | Kenmore 47783 Electric Single Oven
Kenmore oven, mesh coil on oven door.
Yes you can replace it. It is a gasket that seals the oven when it is being used. It is heat resistant and vital to the operation of the oven. It is like running and A/C with the windows open.
Feb 28, 2008 | Kenmore 47783 Electric Single Oven
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47783 Electric Single Oven Logo
252 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
