Question about KitchenAid KTT340 2-Slice Toaster
KITCHEN AID MOD. KTT340WH TOASTER. LEVER WON'T STAY DOWN. TOOK IT APART AND ELECTROMAGNET AT THE BOTTOM OF THE STROKE DOES NOT SEEM TO HOLD WHEN LEVER IS PUSHED DOWN. ARE PARTS AVAILABLE. THANKS. EARL G. BOWLIN P.E.
SOURCE: My toaster doesn't stay in the down (toast) position unless I hold it down
I had the same problem with this model. Made sure it was unplugged, took the 4 screws out of the bottom as others did. Pulled off the handle for the toast push down and the knob for the darkness control (it took some effort but came off ok, if you can tilt the darkness knob opposite the number 1 it will come off easier, there's a hook-tab right at the 1 position).
My problem was with one of the points on the 4 copper tabs that come together as the toast is pushed down. The outer copper tab was slightly out of alignment when the toast was in it's latched position and broke the circuit making it never want to latch. I bent the problem one into alignment and solved the problem.
Posted on Jan 01, 2008
ginko
  • 19396 Answers
SOURCE: Kitchen Aid KTT570 toaster won't work
Yep you need to replace the lever.
Posted on Sep 12, 2008
abhishek33
  • 1239 Answers
hi .. try to dissamble.. and clean it . there may some mechanisim problem.. or ther is a link for the manual just verify it :
  • 2976 Answers
SOURCE: Toaster will only toast on one side
You need a new heating element. Here's the link to kitchin Aid customer service. You will need the model & serial numbers to get the right part. Also, you will have to detail which element is out, such as looking at the handle it's the second from the left or whichever it is. Each one has a specific part number and they are not interchangeable.
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service-contact/
Posted on Feb 07, 2009
techcrazy
  • 72 Answers
SOURCE: my toaster only toasts on one side of the
The kitchen aid brand is usually a good one,
i prefer you too replace the toasting elements because in my brand i faced the same problem and i replaced the toasting element . it worked wonders for me
Posted on Dec 29, 2009
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Handel wil not stay down the model no. is 24559 32
Go to the Hamiton Beach website to see if your series has been recalled. I have same model, can't get base off and found recall notice looking for help. My series wasn't but yours might be. Good luck, might get a new toaster!
Oct 23, 2013 | Hamilton Beach Kitchen Appliances - Others
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Toast will not stay down in toaster when lever is depressed, actually lever will not stay down. how to fix it?
Most times this is caused by a build up of crumbs in the bottom of the toaster. There is a small electo magnet that holds the lever down, if it gets covered in crumbs it won't work. Take it outside turn it upside down and bang the heck out of it till everything comes out. If this does not work then check and make sure the magnet is still attatched inside. Other than that, this toaster gets terrible reviews from folks with issues just like yours. I can only assume the electronics are failing on these units far to quickly. It can be repaired if yuou send it in to the manufacture but that is really not economical. I hope the upside down banging cures the problem.
Jul 03, 2011 | KitchenAid KMTT200 2Slice Toaster
For some reason, the mechanism to hold down the toast is not working and it keep popping up as if it is stuck on the ''cancel'' function.
When this happens it is usually due to the fact that the electronics inside the unit has failed, and will not activate the hold in relay.
Time for a new one. Repair may be an option, but probably not an ecconomic repair.
Jan 22, 2010 | Kitchen Appliances - Others
Villaware mornin toaster 5555-11 When you put the
When you push the slide down on the side, there's a wire that it pushes down inside the toaster. If the wire gets bent down a bit, pushing the slide down doesn't push the wire down enough. The wire is like a teeter totter. When it gets pushed down, it closes the circuit which turns the toaster on. The reason why the slide doesn't stay down is without energy, the electromagnet doesn't get engaged. That's what keeps the slide down. You need to remove the 4 screws on the bottom, and the 2 screws that hold the legs on that also hold the side on with the slide. Once the side is off, take a pair of needle nose pliers and bend the wire up a bit that acts as the teeter totter.
Jan 03, 2010 | VillaWare Mickey Mornin' 5555-11 2-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Toaster won't stay down but does heat
I had the same problem. I opened up the toaster and found that the electromagnet that holds the plastic clip to keep the toaster down had a tiny crumb between the magnet and the metal plate. I cleaned the magnet and it is working fine again. We spent 6 months burning toast by holding it down with a chopstick wedged between the lever and finally took a shot before I went to buy a new one. Took me all of 15 minutes.
Jul 08, 2008 | Breville CT20 Retro Classic 2-Slice...
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Dec 27, 2007 | Kitchen Appliances - Others
KitchenAid KTT340 2-Slice Toaster Logo
355 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
