Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Side sprayer will not stop dispensing water after handle is released, seems like something is stuck or calcified within. Any suggestions?
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Your Price Pfister Marielle faucet has a lifetime warranty. Call Price Pfister and ask them for a free Sprayer.
Posted on Sep 08, 2010
Sprayer on carpet cleaner won't release water
Hello! If your Dirt Devil carpet cleaner is not dispensing cleaning solution, there may be air buildup in the line. Try priming the trigger.
1. Plug the cleaner in.
2. Recline the handle and pump the trigger about 30 times
3. Power the clean on.
4. Hold the trigger in for abut 30 seconds.
The cleaner should start to dispense the cleaner. Hope this helps!
Aug 27, 2014 | Dirt Devil Carpet & Rug Shampoo 1700912044
Water leak electrolux
Good Morning atgltd,
So I understand that your water dispenser continues to release water for several minutes after pouring a glass of water and that it also randomly dispenses water. It sounds like something could be going on with either the dispenser module or the water actuator. Give the refrigerator a hard reset. You can do this by either unplugging it or by switching the breaker off that it is connected to. Leave it off for 3-5 minutes. Connect the power back, and if you are still having the same troubles of the dispenser releasing water, I would suggest that you contact a local authorized technician to see what exactly is causing the water to continuously dispense.
-Best Regards-
Jan 24, 2014 | Frigidaire FRS3R5EMB Side by Side...
Ice maker, water panal on side by side refigerator not coming on when depresing handle
The water line could be frozen. Remove the water filter and see if it frozen. Also, see if the water dispenser works with the filter removed.
Sep 09, 2012 | Maytag MSD2572VEW (25 cu ft) Side by Side...
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
403 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
