Question about Refrigerators
Danby propane refrigerator won't work. I've tried "burping" it for almost a year now with no success. Any suggestions? Is there a Danby service store in the southern or mid-Utah area or Grand Junction, Colo? Thanks.
  • kingdragyn Sep 01, 2008
    The unit was defrosted, and will not go cold again. I have taken the flue apart and polished the thermo couple fin (previous problem from 2 yrs ago). I have extinguished the pilot, and had it properly re-light (hense, not a sensor or "burping" issue). Any suggestions? I have not pulled the burner assembly apart to clean it as I am unsure of the type of solvent to use (as well as it was a very not-fun item to work on 2 yrs ago).
    Any help is highly appreciated. chance_nygard at yahoo dot com
  • markdsr Sep 28, 2009
    My propane refri won't get cold the flame went out and refired it up but it won't cool what do you think the problem is
Check if the orifice is clean.  If not, dissassemble, soak it in solvent and blow with pressurized air.  Do not put wire through the orifice as it will surely change the size and wreck the said part.
Posted on Aug 04, 2008
These R/V ammonia absorption refrigerators are not very reliable..If the burner unit fires up and the tube coming up out of it gets hot but the finned "condenser" section stays cool, no fluid is circulating. The "evaporator" or "percolator" section, inside the insulated heat box, is plugged up with corrosion or crystallized solution that is the result of operating off-level. If they are not perfectly level, the solution does not circulate properly, the percolator overheats and deposits form, plugging the tube. The "cooling unit" can be removed from the case and sent off to be rebuilt. Sometimes, if you are very lucky, you can dislodge these deposits by inverting the unit and tapping on the tubes near the burner section. If this works at all, it's usually temporary.. For repairs, Google "Cool Fun"...Good Luck..
Posted on Apr 28, 2010
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Won't cool on propane. Thermostat doesn't change the flame at all. After "burping" it several times without success, we have removed the thermostat, hooked it up to electric - which is fine for now in...
check the line from the inlet valve to the thermostat.Mine was 1/3 plugged from new,poor workmanship after cutting the line ,no one cleaned the inside of the pipe
Aug 04, 2010 | Explorer Appliances GRQ15 Top Freezer...
My propane fridge will not get cold
You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
The chemicals can become seperated in the wrong areas of the interior components.
Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
If the burner is working correctly, then you should see some results.
Oct 30, 2009 | Refrigerators
Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Aug 12, 2009 | Danby DPR2262 Top Freezer Refrigerator
Danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Thanks,
Ari
Renata BC
hi_ari@yahoo.com
Oct 06, 2008 | Refrigerators
Our Danby propane refrigerator has given us sterling service for about five years, but it has suddenly stopped cooling in the refrigerator box-the freezer still works. Any clues?
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Apr 17, 2008 | Danby Refrigerators
Propane refrigerator is too cold
You have a defective thermostat. Change it.
Nov 18, 2007 | Danby DPAC10061 Air Conditioner
Refrigerators Logo
2,063 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
