Question about Kodak Carousel 4400 Slide Projector
I have a 760 H Carousal projector which will nor advane the tray to the next sidle. Souation?
    President:
  • Kodak Master
  • 412 Answers
If your projector neither advances or reverses the slide tray, then you most likely have a broken "link". This "link" connects the slide change solenoid to the slide change mechanism. Over time this part becomes brittle & cracks, rendering slide change non-functional. This repair needs to be made by an authorized repair dealer.
Posted on Nov 03, 2010
How do you load slides in the tray and then into the projector?
place the slides upside down and in the way you will see them on the screen place in the tray
then place the end of the tray into the projector to the first click
from on it is a matter of pressing the next button
Feb 22, 2016 | Argus 500 Slide Projector
My kodak carousel auto focus 760 carousel does not move but the projector makes a noise when I press the buttons how can I get it to move
Your Carousel 760 Slide Projector is about 45 years old. One of the problems I have seen as Carousel Slide Projectors age is that the plastic parts in the projector get brittle and break. Given your description of the observed condition is that probably either the gear on the focus motor shaft or the gear it interfaces with (or both) that is broken. Given the age of the machine, parts will be tough to locate. Try: www.micro-tools.com
for the best chance to locate those parts. Good Luck !! Jim
Sep 07, 2013 | Kodak Carousel 4600 Slide Projector
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Kodak Ektagraphic AF -2 carousal not rotating
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Nov 28, 2012 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
I have an old Kodak 760 carousel projector with 140 slide rotary. Can I get replacement rotary slide holders?
You can buy new & used Slide Trays for Kodak Slide Projectors from: www.vinevalleyimaging.com They have amazing connections with slide projector users!!
Oct 15, 2010 | Kodak BC-4401 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
We have a carousel and the tray will not rotate - could you give us a hint of what to try. We would like to view so we can move the slides to DVD. Thanks
First of all: Does this happen with every tray? If not, check the suspect tray's locking ring to make sure it's tight & secure. Then turn the tray upside down & make sure the bottom plate is in the "zero" position. Try the tray again.
Next: Is the motor running? Can you feel air being exhausted from the rear of the projector? If so, try cycling the projector with no tray on it. If the levers move in the cut-out on the top of the housing, try pushing the "Reverse" button for at least 4 cycles (this clears a cycle jam) and then try to place the tray on the projector & cycle it. If you still have no luck, then it's time to take the projector to an Authorized Repair Dealer - the projector requires servicing.
Aug 10, 2010 | Kodak Carousel 5600 Slide Projector
Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
Feb 24, 2010 | Kodak Office Equipment & Supplies
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
Kodak Carousel 4400 Slide Projector Logo
132 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
