Question about Toshiba Computers & Internet
I need to strip my laptop back to factory but i can't get it to go to the desktop it will turn on but will only make it to the screen that ask how you want to start up windows i don't seem to get past that page can you help me i have all the disk that came with the laptop but when i try to use them they tell me i have the wrong disk & i know they are the right ones
  • Lorraine Jacobs Sep 07, 2010
    okay that woked but the only thing i get is a screen that says wrong machine I have the repair patch on a flash drive but can't get it to install.
You will need to get your computer into BIOS and set the boot priority to #1 to get your laptop to boot from your restore CD. The reason why it stalls on the start up windows page is because you have picked up a virus on your hard drive. The most standard keys used to enter a BIOS screen is F2 or Control + Alt + Esc. After you get into BIOS (BIOS is a black and white screen) Press "Delete" to run setup and then tap the arrow key until you have "Boot" highlighted. Press "Enter" and then tap the arrow key down until you have the "1st Boot Device" highlighted, now press "Enter" Tap the arrow key right until "CD-ROM" is selected as the "1st Boot Device" then press "Enter" Tap the arrow keys up to the "Exit" tab. Press "Enter" and then press "Esc." This will allow your computer to boot from the disc when you put the CD into the optical drive and it will began to reinstall your operating system to original factory settings
Posted on Sep 06, 2010
  • Toshiba Master
  • 11,800 Answers
First of all you need to get into the BIOS - the key to press will be written in the first image that appears. If you miss it just restart and try again. In the BIOS you must set a new boot order - put the cd first. Now put the disk clearly labeled the Windows Recovery disk and reboot one more time  - the laptop will boot of it and the return to factory process will start
Posted on Sep 05, 2010
  • Azrael SRL Sep 07, 2010
    If you get the "wrong machine" message then the disks you are trying to use aren't the correct ones - and nothing you can do will fix that.
    Either order a new set of disks from the manufacturer or install Windows using a retail disk (or a non-original disk that you can borrow from somebody) and your key. In that case you will have to download and install the drivers yourself.
    Master:
  • 515 Answers
It depends on the model of your laptop. Mine is a toshiba satellite and I hold down the 0 key while powering on to enter the restore to factory default options. Some other model will respond to the C key. You manual should have something about that. You can download the user guide from the following page by clicking on the Download tab and select the model of your laptop.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073769651&rpn=undefined&modelFilter=100CS&selCategory=2756709&selFamily=1073768663#
  • Donald Huang Sep 07, 2010
    Did it tell you it is the wrong machine after the restoration or before the restoration begin? I mean the message saying restoring please wait etc. Did you have your hard disk replaced before? Would you make sure there is no CD, DVD, ZIP disk, SD disk or flash drive plugged in when you do the factory default restoration. If the hidden volume for restoration is corrupted or malfunctioning, then you might have to send it back to manufacture to do a repair on that volume. If you changed any hardware or BIOS setting on your machine, you may try to change it back for restoration and then change it again and update the drivers. Is the patch you mentioned a download from the manufacturer's web site for that hidden restoration volume? Can you tell me the detailed model number of your laptop so I will be able to check that. You might also try to use recovery CD image downloadable and burn a CD of it to boot your machine and perform a restoration.
I cracked my screen now im using a monitor well one day i put it back to factory settings and went through the set up now it will not let me put it on the monitor. now i have split screen now i have to...
hi there:) i need to clarify a few things to help you better. 1) make & model # of your computer 2) do you mean that you restored the BIOS settings to factory condition? or do you mean you did a factory restore to the operating system?...i ask this because the settings to do what you want should be in the bios which you access by turning the machine off and back on again and wait for a prompt that says press f2 to enter setup or press escape to enter setup (depending on what computer you have) but DON'T BLINK or you will miss it. hope this helps but if you need anything else just ask:)
Jul 30, 2011 | Computers & Internet
I tried to use the ctrl f11 to reformat my drive and it does not work
Ctrl + F11 works with DELL desktop/laptops with XP operating system to restore computer to factory settings, that too if your recovery partition is intact. So, If you have the same configuration and you are pressing "ctrl + f11" correctly on the dell logo when it comes in the begening, It should work.
If its not then your recovery partition might be damaged and you need a windows disk to repair/reinstall windows.
Otherwise, if you are using any other operating system like "windows vista" or "7", follow the below process.
Power off the laptop. Remove any peripheral devices such as speakers, printers or flash drives that are not necessary to this operation. Connect your laptop to power/adapter.
Very Important: Please make sure you have backed up all important data because restoring your device to factory settings will result in loss of all data and software, Though all software that came preinstalled with the computer will come back.
1. Backup your important data in external hard-drive or flash drive.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. Choose your keyboard & language options and click OK
6. On the "System Recovery Options Screen" click "Complete PC restore" which is probably the second last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. Click "Next"
10. Click "Yes"
11. You may notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish".
13. Computer will restart and it will boot to desktop just fine. It might ask you to configure some settings as this is equivalent to starting a new computer.
Cheers.!!!
May 15, 2011 | Computers & Internet
How can i set my toshiba equium l20-197 back to factory settings?
I am assuming that you have Windows Vista or 7 operating system. If you have any other operating or if you are not able to reach the "repair your computer" option explained below then contact the toshiba support for recovery CD's.
Follow the below steps to restore your Vista / 7 laptop to factory settings:
9. Click "Next"
10. Click "Yes"
13. Computer will restart and it will boot to desktop just fine. It might ask you tao configure some settings as this is equivalent to starting a new computer.
Cheers.!!!
My laptop screen is dark. I plug the laptop in a power strip in the family room and the screen works fine. I put it back in the other room, plug it into the power strip and the screen does not come on. The...
You have created a power drop with too much load on that circuit or you have a bad receptacle. Try plugging it in directly to the wall outlet in the other room. Let me know if this is helpful, we can go further if necessary.
Nov 08, 2010 | Computers & Internet
How to reset back to factory settings
To reset your laptop to its factory state you need to restart or turn it on, then just tap F10, It will ask you on how would you loke to restore then select Restore system to factory settings. Usually it would ask you for a password just etern six zeros "000000" it should work. Please wait until the restore process is completed.
Note: All data will be deleted so make sure you back up them first before you do a Restore to Factory Settings
Thanks for using Fixya
Aug 01, 2010 | Acer Aspire One PC Notebook
My computer keeps going back to the screen asking
Reboot the computer, on start up, press Alt +F10 and set your computer back to a earlier date or do complete restore, hope this helps!
Mar 19, 2010 | Sony VAIO VGN-FS742/W Notebook
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
Micron PC will load windows, but then nothing!!
turn off pc.
turn on pc...as it boots press f8 to get into safe mode.....
when in safe mode ..
restore pc to earlier week
Sep 15, 2009 | MPC Computers TransPort T2300 Notebook
Screen is empty,blue nothing works...
Try booting up your laptop to safe mode by pressing F8 as soon as you turn on your laptop.
Choose safe mode and see if you can get in there. If you can then choose to restore your system back to the last date it was working properly.
If you can't do anything in safe mode either then that means the operating system is corrupt and you need to restore your computer back to factory defaults either by an internal factory restore on your ASUS or the discs if they came with it.
Aug 10, 2009 | ASUS Eee PC 701SD 8G Notebook
Fault on screen everything very faint
I stripped down the laptop to see if I could locate a back light bulb.
I removed and replaced the plugs powered the laptop back up and all seems to be working well
Thanks anyway
Dec 30, 2008 | Toshiba Satellite 1200-S122...
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
