Question about Maytag Dishwashers
DISHWASHER IS LEAKING AT THE BASE OF THE DOOR.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 07, 2010
Bosch Dishwasher drain mechanism starts itself a few hours after a completed cycle and won't stop. I reset the dishwasher, but it remains unusable for a few days. If I turn on the dishwasher, th
this could mean there is water leak and it collects at the base of the dishwasher leading to moisture detection circuit tripping. when you leave it for a few days the water dries up and trip is removed. check door seals for leak most likely at the base of the door. turn power off when working on dishwasher.
Jul 18, 2012 | Bosch Dishwashers
Bottom seal at the base of the door is leaking badly
Leaking Dishwasher
heatman101
Mar 16, 2011 | Whirlpool Dishwashers
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My dishwasher is leaking out the front. It drips from the lower left hand corner. Any suggestions to what is causing the leak?
Either the tub gasket needs replacement (item 3) in this diagram. or the door base gasket needs replacement. Alternatively, the door vent seal could be leaking. Item 4 in this diagram.
Hope this helps.
Jan 10, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Our Dishwasher is leaking out the sides bottom sides.
The door of every dishwasher has a compressive rubber seal. When you close the door, it compresses to prevent the water lealking out. Yours has perished and a split is allowing the water to leak out. You just need to write down the model and serial number (for good measure) and contact the makers parts supplier. Buy the new seal and install. If you are not confident to try this yourself, a repairman can be booked to do it for you, but it's not difficult, the seal slides into a guide track (at the top internal centre of the door) - the track continues down to the base of the door, across the base, up the other side and when installing, you simply inch it into the guide around the door perimeter until it joins again at the top.
A bit like putting a belt through belt loops...
Apr 07, 2010 | Weber Genesis Silver C Premium Grill
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Leaking dishwasher
There are screws on the inside of the door on a lot of those try to tighten them down a little sometimes that can cause a leak.
Oct 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
