Question about Sony Televison & Video
How do i know which pico fuse is bad on my circut board
  • 10,594 Answers
This can be tested with multimeter only, set multimeter on continuity and check pico fuse both pins, if meter shows zero ohms resistance that means pico fuse is good.
Posted on Sep 05, 2010
What are the specific pico fuses for my RPTV
The amperage is marked on the board right next to them--likely if they go to the convergence circuit they will be marked 5a or 5 amp.
Usually but not always there are more at the convergence chips.
I presume you did not look closely at the board where the two you found are---Sony marks everything.
Jun 15, 2012 | Sony Televison & Video
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
Convergenc problems w/ RCA HD52W59 HDTV
sorry but u replace the incorec part , the board which control the convergence voltage on and off is the deflection board , now this board is about $100 - 150 , or if u want to fix it , just solder the flyback , just go to radio shack and get a 25watt solder station and solder rosin , also check for bad fuse , this fuse it dont look like the others , this is a 1/2 watt 250 pico fuse , and is next to the flyback , look like small brow squer little box , there is 3 and the one that is bad is the one in the middle , this 3 pico fuses are togethere u cant miss then , good look
Apr 16, 2010 | RCA HD52W59 HDTV Projection Television
Source for pico fuses for the Mitsubishi WD-62525 Power Board
Tries Websites Tv repair World.com,Tvrepairkits.com and Ebay.com look for the pico fuses.
Mar 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Massive Convergence problems even after replacing IC's.
See a pico fuse HERE and find PS8001 to PS8006 on D board of TV
Mar 18, 2009 | Sony KP-65WS500 65" Rear Projection...
Cant tune red bulb
Check pico fuses F9A04 and F9A05 if either one of those picos are open it means the convergence Ics are bad along with the picos. Your set uses two STK392-570 ICs and the two picos are both 5amp picos. You can get replacement parts and installation instructions at the following link.
http://servicemanuals.vstore.ca/
The pico fuses are located on the second board from the right heres a pic of where they are.b86c4db.jpg
Nov 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Pico fuse
It's on the T-con board itself at location Cp1 which you will find printed on the board itself.. The fuse is a tiny s/m (surface mount fuse but you can use a pico fuse of same value. According to schematics it's a 1.5a fuse. Simply solder one across the s/m fuse and if it opens then change the board. Samsung p/n# Bn81-01286a
To test the fuse use a VU meter set to continuity.
Pico fuses are readily available at almost any electronics supply outlet. I get mine from ACME Sales in Florida (least expensive) but even your local Radio Shack might sell them...
Bill
Sep 04, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
811 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
