SOURCE: IPAQ rx3115 would not bypass the screen aligning
I experienced the same problem with my rx3115 after having it for 3 days. It is working again, fortunately. I removed the battery from the device and left it alone for 24 hours. I then reinstalled the battery and connected the charger. When it powered up, it went through the initialization process in the same way that it did when I first used it. I hope this helps you out with your iPAQ.
SOURCE: Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
SOURCE: stuck on "align screen"
your touch screen gone just change your touch screen it goes back to normal
SOURCE: Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
SOURCE: My ipaq h5555 wont let me get past the align
do a reset ( like full rese) or if you dont want to leave it off for a few hours and turn it back on AND DONT GO TO THAT SCREEN
