Question about Samsung MW1080STA Microwave Oven
Microwave oven built in
When running for some time, like baking potatoes, it runs for about 8-10 minutes and then turns off because of overheating. After a while it resets itself and can be used again. It is very new.
  • William Miller
    William Miller May 11, 2010
    Assuming the internal cooling fan is working (is it?) then I would say you have a dying magnetron.
    It's very important for unrestricted cooling air flow to be present.
    Please check the air flow and let us know what you find.
  • Samsung Master
  • 9,098 Answers
If it's less than a year old, you should contact the manufacturer for free warranty repair.
If it's older than that, the magnetron should be covered for anywhere from 5-9 years.
I would certainly contact the manufacturer. If you don't have your owner's manual, please reply back with your brand and model number so we can help you link up with them.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
NO HEAT
Circuit board is bad. Cheaper to buy new microwave.
Sep 19, 2009 | Amana AMV1162 Microwave Oven
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Microwave Dead after burning up potato
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Feb 06, 2007 | Kenmore 60659 Microwave Oven
Samsung MW1080STA Microwave Oven Logo
146 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
