Question about Sony VAIO VGN-T370P/L Notebook
How to remove the hard drive from sony vaio vgn-t370 p
  • 304 Answers
Hi fcorey1.
You may remove or replace the Hard Drive by referring to the Service Manual.
You may download the Service Manual for the VGN-T370P Notebook from the below link:
http://www.eserviceinfo.com/download.php?fileid=28689
Please open the above link to download the Service Manual.
Hope this helps.
Please feel free to contact for further information and assistance.
Posted on Sep 08, 2010
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Need hard drive for Sony Vaio VGN-FS742/W
If it's an IDE? Newegg has a 320GB. SATA can go much bigger, but Sony linked your model to a IDE hard drive.
http://www.docs.sony.com/release/994630300_Rev_D_NO_PHONE.pdf
Oct 13, 2012 | Sony VAIO VGN-FS742/W Notebook
Problemas con el audio en sony vaio vgn-fs630w
You can download the audio and device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Dec 29, 2011 | Sony VAIO VGN-FS630F VGN-FS630W VGN-FS635B...
How to remove hard drive from Sony Vaio Laptop VGN - NR110E?
On the bottom of the laptop there should be a cover for a quare or rectangle shaped slot, most likely with two screws in it. Unscrew these, and the hard drive bay will come loose. Just unscrew it from the bay and it should be free.
May 02, 2011 | Sony Vaio VGN-NR110E/S Notebook
How do i remove the harddrive from a sony vaio vgn-sz120p
Hi dekoreya.
You may remove the Hard Drive of the Notebook by referring to the Service Manual.
Link to download the Service Manual for the VGNSZ Series Notebooks:
http://tim.id.au/laptops/sony/vgn-sz.pdf
Please download the above Service Manual from the above link.
The Service Manual has the detailed information to remove the Hard Drive.
Hope this helps.
Aug 03, 2010 | Sony VAIO VGN-SZ120P/B Notebook
How to change hard drive on Sony VGN-N130G?
I need the model number printed on the front of your case, VGN-N130G does not exsist on the sony web support page. http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
Usually there is a cover under your laptop that is marked.
Remove 1 or 2 screws and your harddrive should just slide out.
Jul 14, 2010 | Sony VAIO VGN-N130G/W Notebook
Sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
Jan 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Jan 10, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-T370P/L Notebook Logo
697 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
