Question about Averatec 3200 Notebook
NO POWER, CANNOT OPEN CASE
PC CHIPS A530 TM5600
Power failed, no charging, adapter fine.
Cannot open cade POWER SOCKET GETTING HOT AND KEEPS LOSEING POWER(power unit and leads ok) cannot get open up case to replace socket- tried taking out several screws but still cannot get apart (40 years TV engineer)
    President:
  • 2,712 Answers
THIS document may help in dismantling the case. Although it is for the HP, it may prove useful.
Posted on May 12, 2008
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    It looks like your battery is dead and you are trying to recharge it, thats why the heat. Try replacing the battery first, and see if that helps..
  • 3,037 Answers
Alright so you need to pull all of the screws out on the bottom of the laptop. The casing will most likely require a little force due to any sealant that the company used if this is the first time opening it. you may also notice a little locktight on the screws that you have pulled out. You just need to run your fingernail or a flatheaded screwdriver around the edge of the panel and pry it off little by little.
Let me know if you need further directions or have other questions and I would be glad to do what I can.
thanks
A530 syntax a530 tm5600
take the old with you to your nearest eletronics shop and get a replacement charger
Oct 24, 2013 | Syntax AKA3000 PC Notebook
A530 TM5600 LAPTOP
Can u please tell me your laptop's brand and model number?
Dec 06, 2007 | Computers & Internet
Solution for Two Beeps - POST/CMOS Error
Usually Memory stick failed or loose in socket can also be video card.
Power down pc. and remove power cable from wall socket
Open case
IMPORTANT. to prevent static discharge damaging PC keep one hand touching the metal of the case.
Unclip and remove memory sticks and video card
Do not touch the gold connectors with your fingers
Replace parts making sure firmly in place
Replace case cover
power up pc
If still have problem one of the compnents has likely failed
Mar 01, 2013 | Computers & Internet
Hp 4510s not charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 01, 2012 | HEWLETT-PACKARD HP ProBook 4510s Notebook
Dv-7 is not getting charged . even the white indicator on the side near charging port is not coming ON. checked the ouput of the adapter, its fine but as i hook it up there is no response .
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.Thiscan be repaired but it requires the laptop to be completely dismantled to getat this power socket and repair. If you cannot DIY then I suggest you get aquote first.
Nov 03, 2011 | HP Pavilion dv7-1245dx Notebook
Not open i push d switch open pwer light not continue to open
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's power socketcould be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Mar 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My hp 6735s laptop battery not charging says pluged in but not charging only 1 year 6month old
r u getting the message when on AC power that the "smart AC adapter is not providing enough power" ?? If yes then remove the battery and c if the laptop works fine with just the adapter plugged in ...
if yes then take power cord out of the adapter from the end that goes to the wall socket .. that side is removeable ..then plug it back in and flip the way its plugged into the wall socket .. c if this helps ..
Oct 22, 2010 | HP Computers & Internet
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
Bad Power jack on the motherboard and possiably a hairline crack on the board. I can help you please respond here.
Dec 06, 2007 | Toshiba Satellite P105-S6024 Notebook
Laptop no power A530 TM5600 PC CHIPS
if u have already checked the adapter then make a power drag trial, that is use the adapter with any other laptop of same voltage rating and if the lap works there is no problem with adapter as some adapters fail to deliver power at the time of consumption and gives correct multimeter reading.If the problem is with ur laptop surely u have to open the case,there after chk for dry solder and then chk power regulator ics ,chk short circuit of components etc
Averatec 3200 Notebook Logo
49 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
