Toshiba LS25-S119 Start Up Problem
Laptop when depressing power button, starts to spin up hard drive for maybe .25 second then shuts off. The power lite illuminates greet for about one second.
This occurs both with the battery inserted, and removed.
    Genius:
  • 1,019 Answers
you,ve got 1 of several problems here.
1:- A Virus may have locked off the hard-drive.
2:- The RAM is faulty.
3:- The CPU is faulty.
Ensure the battery is left on to charge fully, and retry to boot the System.
Mike @ compurepair.
Posted on May 12, 2008
Problem with Toshiba Satellite L455-S5009 laptop Push the start button and i sounds like i is starting and 4 -5 seconds it shuts down. Is it worth working on?
If you have friends or family that want one then i would give it a go, unscrew the hard drive cover take the hard drive out and give it a good blow, if you have another hard drive to try then give that a go, maybe the bios needs sorting out, you can try taking the battery out no power, press the on/off button for a minute then put it back and see what happens, i take it you have a power lead to plug it in? this is another thing i would check, if all fails after this then its up to you lol, you couls always sell in parts on flea-bay, hope this helps ;))
Nov 10, 2013 | Toshiba Satellite L455-S5009 laptop
How to restore toshiba satellite L25-S119 to factory settings
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.
6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
May 04, 2013 | Computers & Internet
Toshiba tecra A9 when I press the power button I get the power indicator light and the hard drive light. The hard drive starts to spin for about 1 second and everything shuts off and all the lights are...
there is a short circuit in your laptop. the power circuit cut off the power fpr protect the circuit. need to dissemble and remove parts cd hdd and ram other parts you can remove. power up and check the continuous run , no need video, after replace the ram test the display. also your lcd is bad or converter may be shut off, there test without lcd.
Oct 06, 2017 | Toshiba TECRA A9 PC Notebook
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 laptop-No image on screen but the fan powers up when the power is turned on. The Power button illuminates then turns off but the fan continues to run.
well your leaving a lot to the imagination..is the hard drive light working..plug it into a external monitor then boot it..then we can go from there..
Feb 18, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba L-25 Laptop
Got one here. Please remove the battery and power laptop on ac only. Please press the power button for 10 seconds until it turns on then immediately press on the F12 key. Release F12 upon seeing the boot selection menu. Please select the CD/DVD drive. Follow the rest of the instructions until the Recovery to the Out of the Box State. Hope this helps. Thank you.
Sep 21, 2008 | Toshiba Satellite L25-S119 Notebook
Ribbon cable for keyboard on Toshiba Satellite
check thye pins may be there bent try to straighten them then check if thats the actual port it should fit in cos iv worked some number of laptops it has only a one way drive in thats is things can only go one way.
thanks
May 18, 2008 | Computers & Internet
Toshiba satellite m40x
Do you hear the fan come on? Do you hear the hard drive spin up or notice the hard drive light come on? I relaize it may be a short spurt.
Jan 06, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105 PC Notebook
When you turn it on, do you hear any activity? Motors start working, fan spinning, etc…? Try to connect an external monitor and start the laptop. Check if you can get any video on the external monitor. If the external monitor is dead too, try to remove the battery and start the laptop from the AC adapter. It also might be a bad memory module or a bad connection between the memory and the motherboard. Try to reseat the memory module, move it to the second slot. If you have two memory modules, try to remove them one by one and turn on the laptop. Also, try to remove the hard drive and see if you can boot it to Toshiba screen without the hard drive installed.
There is no special button to reseat the BIOS settings. To do it, you’ll have to access the BIOS using F2 button on the laptop start up, but as you have no video, you cannot access the BIOS and set it to defaults.
I
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
