Question about Samsung Digimax 301 Digital Camera
I PLACE MEMEORY CARD INTO CAMERA AND IT COMES UP SAYING ERROR AND THEN CARD LOCKED AND A FLASHING CARD SIMBLE
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 06, 2010
How do i turn on the internal memeory on the S9600
the camera should automatically store onto the internal memory if there is no card inserted. if there is a memory card insterted it will automatically store onto that
Jul 01, 2013 | Olympus Fujifilm Finepix S9600 Digital...
I am currently using a cannon a480 digital camera with a 2gb memory card. i just inserted my memory card into another camera (benq dc2410) and it said card error, needs formatting. now when i placed my...
As long as you didn't format the card your images should still be in there. Get a card reader (usually like $10) and connect this to your computer. With this you can just drag and drop the images to your desktop. Once you do that format the card on the camera you want to use it with and don't use it on any other devices. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot A480 Digital Camera
Camera says memory full and no memory card rca ez200a
you have 2 memeorys internal and external,if no meme card installed its your internal memeory,accessed via camera menu....tgood luck
Nov 23, 2010 | Audiovox RCA EZ200 Flash Media Camcorder
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I didn't get a memeory card with my new camera.
First, new cameras don't come with memory cards anymore. Make sure the slide switch on the side of the card is in the unlocked position. Then, format the card in the camera.
Dec 19, 2009 | Canon PowerShot A540 Digital Camera
Short video
If you do not have a memeory card then you will not be able to record a long video as this camera only comes with 10MB. You will need to buy a memeory card.
Feb 04, 2009 | Samsung L100 Digital Camera
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Canon ixus 75 memeory card
On the SD card itself there is a little tab that slides back and forth. It should be closest to the the end you put into the camera first. If it broke off, then the camera is stuck in lock mode. If this is the case, it's not worth trying to glue something in its place...just invest in a new one.
Jan 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memeory card error
many users have the same doubt. as per canons manual:
if any error is displayed when using your memory card do a low level formating of memory card.
but what to do for pictures in it? get a memory card reader from market. its very cheap. its also advisable to use memory card reader to transfer your photos rather than using direct connectiin to computer. bcz any lekage current from computer may damage the camera in some way.
after doing a low level formating then transfer photos inside memory card from system, put it in ur camera, then enjoy.
hope you are clear with your problem. please give a feedback.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Samsung Digimax 301 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
