Cannot down load address book or pictures to high speed USB 2.0 drive
  • Prasanna kumar May 11, 2010
    please tell me brielfy what are the errors you got .
    Genius:
  • 1,224 Answers
Save as data file compressed zip or win rar folder and then save to usb drive
Posted on May 13, 2008
Can someone help me with my external HDD (MY PASSPORT)
Lots of info there, but what exactly is the problem with the drive?
Dec 18, 2014 | Western Digital 1TB My Passport Essential...
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
Slow transfer
It could be that the USB port you are using to transfer the data is not a "High Speed 2.0" enabled port.
Does it give you a pop-up message when you plug it in, one that says "This device can perform faster".
If so, It is not a High Speed USB port. Try using another USB port on your PC.
Mar 21, 2011 | Western Digital My Book (WDG1C3200) 320 GB...
Samsung s8300 how do i speed dial using keyboard
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: [most of this from Phonebook/More/Settings/1 ]
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jan 30, 2010 | Samsung S8300 Ultra Touch platinium-red...
I have several pictures on my computer on Kodak Easy Share. I purchased a Toshiba USB 2.0 8 GB flash drive to transfer the pictures to the flash drive but can't figure out how to use it to transfer the...
Just plug the flash drive in and let your computer recognize it and offer to open the flash drive file up to view. Once it is loaded up then you can simply drag and drop into it. If this is the first time using the flash drive it may need to load some software. When a flash drive is being used a small icon should appear on the lower right.
Sep 08, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Speed dial
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Factory restore
You can export address book:
click File -> Export -> Address Book -> Seleck "Text file(comma separeted values)" -> select folder on your usb drive you want to save address book, click next, select what info about your contacts you want to export.
Apr 26, 2009 | Shuttle XPC SD32G2 Barebone
Down load from camera to note book
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as PIcasa.
Dec 18, 2008 | Pentax Optio E10 Digital Camera
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
