Question about Baby Gear
The cost of Reparing Or Replacing a Car Gear Box
I am about to buy an automatic Mercedes A-160 & the seller has told me that the gearbox is Damaged. I am a First time buyer who knows nothing about cars!!! Or the cost of repairs. Below is the description given:
"The car itself is fine other than the fact that when selecting drive or reverse, it displays a fault code "F". You are still able to drive it, however, it goes into 'limp home' mode where you only have 2 gears. 1 drive & 1 reverse. the engine does & has always run well."
I would like to know 3 things please:
  • How much roughly would it cost to repair this problem?
  • How much would it cost to replace the gear box completely? (as appose to a repair).
  • Would the repair & replacement costs apply to both Manual & Automatic Cars?
Many thanks for helping to understand this, I look forward to hearing from you.
Jaz.
  • 2,039 Answers
I know those car are interesting mercedes ,bmw, ect you have to think twise you need lot of money to have a car like that part are note cheap plus it harder to find part compare to japanise or american if you live in the state i mean trany rebuilt is about 2,000.00 and there many oder stuff thant can go wroung be carefull thank you pierre
Posted on May 13, 2008
Automatic gearbox
Most transmission repair shops will have a exchange box that has been reconditioned and will take your transmission as part payment. If you buy a junk yard transmission you may have trouble in a few months time.
Jun 12, 2013 | 1997 Mercedes-Benz E-Class
!995 Model 500SE Benz Sometime back Gear box oil coolantdevice inside radiator got damaged and radiator water went inside gear box. after replacing new coolant device and flushed gear box with oil and...
I cannot tell you why it happened untill we find what actually it needs to fix it,,,,,Is your check engine light on? If it is forget your high priced mechanix and Go to your local auto Zone parts store and ask them to run the scan coder on your car,,,its free there and they wont lie to you,you will get a paper read out and they willl explain the codes that came up and tell what you need to fix the problem.Soubnds like a sensor that controls the shifting of your tranny is bad,,,,Why?,,,Your car is 21 years old,,something is always going wrong with old cars.A car is only good for 5 years than things start breaking down.Fix only what the code says is wrong and get rid of that old car before it becomes a money bucket!
Mar 07, 2011 | 1995 Mercedes-Benz E-Class
Hi, I have a Mercedes A170CDi Auto that has gone into limp-mode on the gearbox. I have had a diagnostics check done and it shows a P1841 Current fault code which is a Solenoid Valve Y3/7y2 3 shift fault....
The code is consistent with an electrical short within the shift motor solenoid. These solenoids open and close fluid passageways within the gearbox that cause clutches engage and disengage with the planetary gear system that make up an automatic gear box. Auto boxes are very involved pieces of machinery and best left to experts so I am afraid it needs a trip to the Mercedes dealership or a good auto transmission depot. It could be that the gear box can be easily renovated by fitting a new solenoid in which case an overhaul rather than replacement will be the cheaper option. Since you have the code for the fault I would phone around for repair quotes.
May 24, 2010 | 1984 Mercedes-Benz 190
Mercedes water mixed with gearbox oil
The gear box and the engine are separated by a clutch and flywheel in the manual and a torque converter in an automatic so I am little puzzled as to how water (presumably engine coolant) got into the gear box. That aside, the only remedy is to drain the gear box and replenish with new oil.
On the other hand do you mean that water is the engine oil if so this will need to be drained and renewed. The only source of water contamination in the engine oil, other than the inadvertent adding of water via the oil filler cap, would be a cylinder head gasket failure allowing water to leak from the internal passages into the oil ways. If that is the case the gasket will need replacing.
Mar 22, 2010 | 1999 Mercedes-Benz E-Class
I have a 1985 Mercedes 300TD While entering the freeway, the engine started racing as if in neutral while in D. after a full stop all seemed fine until about 12 mph, when again no gear. Drives fine in L...
Dear kev4,
The problem seems to be originating from your gearbox. The gear box has two main components that convert the torque of the engine to the tailshaft; the 'torque converter' and the 'bands' within the gearbox. If at higher rpm the car starts to rev higher and slow down then it would suggest that one of these two components are slipping or not functioning correctly.
To fix this problem you will have to take your car to a gearbox specialist who with either reccomend a replacement gearbox, a overhaul of the orriginal gearbox or if you get lucky a new torque converter. Unfortunately this car be a costly opperation but is quite important in reguards to the life of the vehicle.
Reguards luke.
Feb 12, 2010 | 1999 Mercedes-Benz E-Class
Just bought a passat estate . when i first start off when the engine and box is cold know problems .but when the engine and gearbox are hot i find it hard to find reverse gear and a bit tight going thought...
Dose the clutch pedal drive in gear 1" from the floor OR 1"" from the top when you let it out. if its drives when almost out and there is a vibration on the pedal then the clutch needs replacing and it has nothing to do with the gear box or oil
But the gearbox has to come out before you put a new complete clutch in
Oct 02, 2009 | 1998 Volkswagen Passat
I have a mercedes c200 automatic and the pipe from the gearbox to the front of car and returns is leaking what i think is a cling pipe for the transmission fluid but my car wont move from second gear?
The pipe going to the front of the car is going to the oil cooler, then returns back to the gear box.Replace the pipe and check the oil level. with the engine running.
Mar 11, 2009 | 2000 Mercedes-Benz C-Class
X-type jaguar automatic (gear box fault)
I have a 2002 X type (2 litre. done 44000 miles), dash showed gear box problem, (red circle light up). I pulled out and turned the engine off. 5 minutes later turned the engine on. The engine running but the car would not drive either in drive or reverse. Turned the engine off again and on the car driving but not much power. The care is taken to the Jag. dealer and told is misfiring + some gear box faults. Suggesting to change some coils and see (cost about £200+). also possible need to change the gear box costing about £2500+. Please advice. Shall I go ahead with the repair? Should I part exchange.
Feb 15, 2009 | 2003 Jaguar X-Type
Gearbox nutral
Hello, I have worked on Mercedes for the past 20+ years and I can't think of any way to do this easily. The shift lock is tied into your steering lock/ignition lock for safety and theft reasons.
I hope this helps.
CYA, Gator241
Oct 27, 2008 | 2007 Mercedes-Benz C-Class
Servicing my Mercedes C200
Gearbox -> Synthetic automatic transmission fluid
Differential -> Either 90W engine oil or 85W90 gear lubricant
Engine oil -> Not really sure of the weather in Uganda but I take it it stays pretty warm all year long, probably 20W-40 or 15W-40 synthetic
Spark plugs -> Well there could be a long debate over that... if you're having engine performance/missing problems i'd try replacing them right away but with any gasoline ignition system i try to replace the plugs about once a year... plug wires about 5 years... regardless of condition. In my case, i don't usually go for expensive "platinum" or whatever kind of plug that costs about 10 times as much and usually don't do much of a difference... I'd rather buy reasonably priced spark plugs and replace them regularly, and get a much better result and more money in my pockets... because even if you did buy the expensive ones you usually end up replacing them at about the same time you would have the cheaper ones, with the same effect
Aug 15, 2008 | 1997 Mercedes-Benz C-Class
Baby Gear Logo
1,852 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
