Question about Gateway M350 Notebook
On startup I am told to "check fan" or press F1. One of the two fans will not start on his own. I have to start it with a paperclip.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Sounds daft but turn the computer off and hover through the vents
Posted on Sep 05, 2010
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Dear sir, my desktop is hp compaq dc7600 sff. everytime when it starting to boot the following info is appears: "512- chassis fan is not found. press f1". after pressing f1 it's starting to...
The sytem checks for the Chasis fan during the bootup (startup) process. The fan is connected to the motherboard via cable. Turn off the system. Open it and make sure the the cable is connected properly. While the PC is open, press the power button and check if the fan turns on. If not the chasis fan may have gone faulty, which needs replacement. If you find it faulty, you may find and replace the fan by removing the old/ faulty fan by removing the 4 screws and installing the new one.
Hope it helps! Good Luck!
CreativeTECH
May 02, 2011 | HP Compaq d530 SFF PC Desktop
I have problem with my fan when turn on my computer say fan failure press f1 to continued press f2 setup
You should first check to make sure the fan is working. Just open it up and turn it on and see if the fan is functioning properly. If not then you can just order a replacement fan from Dell.
Feb 18, 2011 | Dell Optiplex GX280 (99301) Motherboard
I HAVE NOT LOOKED INSIDE MY COMPUTER, BUT THE FAN BEGAN MAKING A LOT OF NOISE A MONTH AGO. TODAY THERE WAS NO NOISE AND A MESSAGE CAME ON MY SCREEN SAYING "FAN FAILURE- PRESS F1 TO CONTINUE. MAY I USE...
First, if the CPU fan is not spinning properly, you should NOT run the system. The fan needs to be replaced.
If the fan is running normally, you may boot by pressing F1.
Before replacing with a new fan, you can first try re-seating the plug for the fan in your computer. The fan's plug may have been bumped or loosed. Re-seat the plug located at J1F1 as shown in the picture below and be sure that it is properly connected.
Hope this helps.
Sep 28, 2010 | Computers & Internet
Screen wont come on.
first pull out the ram and harddrive one by one and reload the laptop should give you an error code if the computer is reading for those items also try pressing F1 at startup when it goes blank have one at the moment that has that problem and if the fans shut of the hard drive might not be no good......
Jul 26, 2009 | Computers & Internet
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
CPU Fan Failure on Startup
if you have tried changing the fan then the problem is with the motherboard & motherboard needs to be replaced.
Apr 25, 2009 | Dell OptiPlex GX280 PC Desktop
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Jul 05, 2008 | E-Machines eMachines Desktop PC
Gateway M350 Notebook Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
