Question about Dell Inspiron 1525 Laptop
When booting up, the screen says "hibernating," with the "refreshing" circle spinning & spinning. I've tried shutting down & turning the ower off, but to no avail. Any ideas? Thanks
  • Dell Expert
  • 393 Answers
Go to bios setup check the date and time if not corect then set date time save setting exit setup and check ..hope it will be okie..
if same format ur system ...Thanks
Posted on Sep 14, 2010
I accidently shut my computer down with hibernation before leaving. When I come home, the computer will not turn on, no lights no noise, nothing. How do I unlock the hibernation? Or could it be something...
You need to hit the power button just the once to bring it back out of hibernation mode. It may take around 30 seconds until you hear your computer starting to boot back up and a little longer for the screen to come on.
Failing this, you can try a hard reboot by holding down the power button until you hear your computer re-boot. Usually you need to hold around 10 seconds. However using this last method as a final resort will result in your computer telling you that it did not shut down properly.
Jul 08, 2011 | Gateway 310X PC Desktop
Hi I closed my laptop to put into hibernation mode and then noticed 2 days later that the power light was stuck on and not in hibernation. Upon opening the screen back up nothing happened. No lights, no...
You can try this: Shut the computer down and unplug the power cord from the computer. Remove the battery, then push and hold the power button and sing happy birthday to it. Or wait 15 seconds. Then plug the power cord back and try turning the system on. After it boots up, providing this fixes the problem, you may then replace the battery.
Hope this helps!
Feb 16, 2011 | Dell Studio 1737 Laptop
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
Stuck in hibernation
turn system off remove battery...leave alone for ten minutes...have a cup of tea...
turn system on ..leave battery out use mains only.
boot up ..then turn off properly..
now insert battery and happy days.
boot up
Sep 15, 2009 | Compaq Armada E500 Notebook
Same as above I think
first of all never never never use hibernate only use standby. you want you hard drive to crash and loose all you info keep hibernating your laptop.
Jun 22, 2009 | ASUS Eee PC 901 XP Notebook
When ever i turn my laptop on..it boots properly..then ill be typing and it will shut off..or go on standby not sure then i will push the power button...but it doesnt rootboot ...and starts back up where i...
Try this.
Right click on desktop.
Mouse down to properties, & left click.
Left click on screen saver.
Mouse down to Power In monitor power, & left click.
Check your power settings & hibernation settings.
Also some computers are setup to hibernate if mouse is placed in certain parts of the screen (top right or left, Bottom left or right.
Hope it helps.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Jan 12, 2009 | IBM ThinkPad R40 2722 Notebook
Dell crashes and restarts upon sleep_suspend_hibernate
I'm not a big fan of using hibernate or standby, I've seen it cause too many problems, such as the one you're having. I shut my machine down when I'm done, or let it run if I'm coming back within a reasonable amount of time. I've also seen hibernation or standby create operating system errors or glitches, and premature hard drive failure. If the machine is working properly other than hibernation/standby you should shut the hibernation off and just shut the machine down when not in use. If you're getting this error when using the power button to turn off the computer, then the operating system has glitched or is corrupt and needs to be reistalled. If you need anymore help with this let me know.
Jul 01, 2008 | Computers & Internet
Dell Inspiron 1525 Laptop Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
