Question about Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh...
Freezer is not freezing. It defrosted everything.
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
My Whirlpool Refrigerator/Freezer Model #GR2FHTXVQ00 or GR2FHTXVO00 is not keeping food cold. Food is spoiling. Freezer is cold but Refrigerator is warm.
With signs of freezing up in freezer area that would indicate a problem with the defrost components. The most likely reason would be a defrost control board. 2304093 Defrost Control Board
Here is a link to a parts manual for your model=> GR2FHTXVQ00.pdf(1101.27 KB) Look on page 3 and part location 4 That is the=> 2304093 Defrost Control BoardThe next possible parts are the 2314157 Defrost Heater Assembly found as item location 4 on page 9 of the PDF. It may be a good idea to change the defrost thermostat=> 2321800 Defrost Thermostat found on page 3 with item location 28. If you have questions please let me know, Thanks John TrippAppliance 911
Contact Me Here
Sep 23, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Calibrate temp
You need to balance the temp settings. The freezer controls everything and it you have the refrigerator set wrong then the freezer tries to compensate. This means that things get too cold
Apr 03, 2014 | Whirlpool Refrigerators
Frigidaire 18.2 cuft top freezer refridgerator either melts or freezes everything
The defroster heating elements are burnt out and won't defrost and causes system to freeze up. Then it won't cool. Unplug ice will melt off cooling fins then it will cool till it freezes up again. Install new defrost heating element. Replace both.
Jan 15, 2014 | EuroCave Performance 283 Wine Cellar
Please someo one help our freezer is soo cold that everything is freezing very hard, but our fridge is not cool it's starting to warm up, i see can see where the cold air is suposed to come from,
You will need to replace the "bimetal defrost element" and the "defrost heater".
Here is a link to the bimetal defrost.
Here is a link to the heater.
You will need to empty the unit of food and leave the doors open for 24 hours so that all the ice buildup on the coils defrost before you can replace the parts.
Take a look at this video.
Oct 16, 2012 | Roper RT21AKXKQ Top Freezer Refrigerator
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
The Freezer portion keeps on developing frost on the back and does not freeze unless I take everything out, turn the freezer off, and dry everything out. Then turn the freezer back on.
G.E. refrigerators use a glass tube heating elemnt for the defrost system. They are the most common thing to go out on the G.E. defrosting systems. The most common of the elements part # is WR51X10101
Mar 20, 2011 | GE Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing solid. Pulled off back
Your not going into defrost, the fridge cycles into defrost every 8-10hrs for approx 20mins....problem could be multile items, the defrost time, defrost thermostat, or the defrost heater, will need a meter to ohm heater and thermostat...thermostat will be a closed circuit when it gets below 22degrees. ohm the heater out...if both check ok, will be a timer issue. Can do a simpler check....in the fridge section near controls there is a smal hole with a gear on the inside....that is your defrost timer. take a falt tip screwdriver and turn that gear until it clicks, this will put the fridge into defrost...if everything on the heater side is ok you will hear a sizzle from the ice melting
Jun 09, 2009 | Amana ABB1921DE Bottom Freezer...
Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh... Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
