Question about Schwinn Mesa Gs Mountain Bike
I would like to raise the handlebars on my Schwinn mountain bike about an inch. Right now they appear to be all the way down. Can it be adjusted and if so, how do I do it. It is model # S4970YG. Thanks Louie
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
  • 484 Answers
SOURCE: Adjusting seat on a Women's Schwinn Jet Star 26" bike
It sounds like the bike you bought was too big for you. Your only option here is to replace the seatpost with one that does not have this feature. You can pick up a seatpost at a bicycle shop and they should install it for you, too, if they are a good shop.
Hope this helps a little,
matt
Posted on Sep 19, 2009
  • 6 Answers
SOURCE: raising the handlebars
If your bike is older it might have a quill stem.To raise this you have to undo the allen key headed bolt situated where the bar & stem attach to the bike.It is often obscured by a plastic plug to prevent water rusting the bolt head.If this doesn't go high enough an adjustable quill stem must be fitted.
If you have the modern design of stem(A-head)you will have to replace the stem with an adjustable type which can be set upto 60 degrees.
Posted on Sep 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do you raise the handlebar of a Schwinn Ridge
The handlebars stem is an Aheadset-style and as such has spacers below it to set its height. Once the steerer tube is cut to fit the combination of stem and spacers there's no going UP, only down. Stems can be replaced with different rises and lengths. Maybe that would help. A Bicycle Shop would have everything you need and the know-how to decide if you can mount the child carrer.
Posted on May 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do i raise the
Probably. Getting Riser Bars or a riser stem or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Detailed advice...
http://www.sheldonbrown.com/handsup.html
Posted on Apr 10, 2011
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
How do you raise the handlebars?
unfortunately, your bike uses a threadless stem. meaning you cannot raise it, you must replace it with an adjustable one, or get a stem with a steeper angle.
Oct 28, 2012 | Jeep Comanche 29er Mountain Bike
What is the shape of the handle bars on the Schwinn High Timber Girl's bike?
These are certainly not racing style bars; but the modern, hybrid riser handlebar.
They will not sweep back toward the rider as much as a beach cruiser handlebar; but could be adjusted rearward to come closer to the rider. They definitely allow for a more upright riding position than many other handlebars though.10_19_2012_7_26_19_pm.jpg
Oct 19, 2012 | Schwinn High Timber Girls' Mountain Bike...
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
Need to raise the handlebars on Point Beach Schwinn bike
It's called a quill stem.
Google "how to adjust the quill stem on a bike" for video tips or just read this...
Jun 06, 2011 | Schwinn Cycling
How do i raise the handlebars on the schwinn graft mountain bike? Do i need a riser?
Detailed advice...
Apr 10, 2011 | Cycling
How do you raise the handlebar of a Schwinn Ridge AL 26" bike? I want to add a child carrier and I need to raise the handlebar to make it fit.
May 27, 2010 | Schwinn Ridge Al 26" Men'sboy's Mountain...
Raising the handlebars
Sep 29, 2009 | Cycling
How do i adjust the handle bars to go higher?
there is a nut on the lower part of the hadel bars you loosen that up then rais handel bars.
Jul 02, 2009 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Schwinn Mesa Gs Mountain Bike Logo
155 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
