Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
My heater is showing a ignition lockout fault, how can I fix this
    Top Expert:
  • Jandy Master
  • 8,686 Answers
Turn off that resets it check gas to see if on outside unit and inside at gas valve then try again if doesn't light see if ignitor is lighting if not replace if so see if safety circuit is ok
Posted on May 01, 2016
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
What is "Ignition Lockout Fault?"
I wonder why your question ended up in the wrong category.
Now that we know that it is a propane heater and not a TV I still don't know the brand name or model. I think you said 5th. wheel.
Most rv furnaces are are very similar. This is a link to trouble shooting a RV furnace.
http://www.rvforum.net/miscfiles/Furnace_Trouble-2.pdf
Atwood 8531 Service Manual
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
Sep 24, 2014 | Televison & Video
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
Aug 09, 2014 | Hayward Pool & Spa
Indicator says Ignition lockout ?
turn off then turn back on that should clear it
May 26, 2014 | Jandy Laars Lt 400,000 Btu Heater
Ignition lockout
Make sure all gas is turned on to the heater, ignition lockout can be one of several things, the majority of the time its a control board but, it could also be water in the heat exchanger pot, which would keep the ignitor from working, or a bad igniter.
Feb 20, 2014 | Pentair Mastertemp Heater
Ignition lockout code
what is the error code in display, did u reset the board by turning the power on/off
Jun 09, 2013 | Legacy Jandy Lrz250en Swimming Pool Spa...
Getting ignition lockout code
1-water flow ? gas related , is propane or natural gas ?
AO error
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error&cd=7&hl=en&ct=clnk&gl=us
Sep 16, 2009 | Hayward H Series Pool & Spa Heater 400k...
I get an ILO Fault Code and it will not lite
iGNITION LOCKOUT-turn off main power switch(on side of unit) or breaker controlling power to heater. This should reset board. Happy Swimming
Aug 09, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
IF error ignition fault lockout
If it has not fired in some time, the odds are high that a small spider web is blocking the burner orifices. These are the brass fittings exposed at the front of the burner tray. It does not take much to block gas flow. Each burner should have a pipe cleaner run into the orifice. A small zip ties will also work. You're looking for a small web on the end of the cleaner.
The problem lies in the blockage. The ignitor and flame sensor sit at two different burners. Blockage of a burner at those locations will not ignite or will not sense flame to allow the heater to stay on.
Restart after cleaning and see what happens. Otherwise, you may have a bad ignitior.
Dec 30, 2008 | Hayward H Series Pool & Spa Heater 400k...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
332 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
