Question about Toshiba Televison & Video
My SD4200KU will not respond to remote or to buttons on the front. Display says "2". this happened right after a dvd was inserted and it had finished that warning about only for home viewing, etc. I checked remote batteries--ok. I disconnected power and reconnected--still nothing. Any suggestions?
  • Toshiba Master
  • 11,800 Answers
The firmware has crashed - either because there's something on that disk that your player can't do or the processor has failed.
Dismantle the unit and take the disk off. Find out if your mainboard has the reset contacts on it - if it does then power the unit again and join them for 5 seconds then power the unit off.
Look for any failed parts - bulging capacitors, burned resistors, loose wires - and fix them.
Reassemble and try again. If even after that the player is still frozen then you can junk it, reflashing the firmware will cost you more than the player is worth.
Posted on Sep 05, 2010
Vcr not responding to remote
If hooked up right the play button should work, if on wrong channel and no switch on rear to select 3 or 4 it might be the remote.
The remote can itself be tested--all shops have a tester--point remote at it and press any button and tester will react or not.
Many digital cameras can also be used in the same way in a VERY dark room. Point remote at the powered up camera and look for a tiny flash on the camera display itself when pointed at the camera and buttons pressed.
Test the remote first.
Dec 12, 2012 | Televison & Video
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
The remote does not work
Hello my Marantz dv4100, didnt respond to my remotecontroll, Remote was working. remote from my philips dvd722 works fine with this Marantz-dvd too.
i found 2 solderings at the back of the front circuitboard in remotecontroll receiver optounit at the left side of dvd-display, pins 1 & 2 needed resoldering, had cracks in solderings. after that it was working fine again.
hope this helps u too.. good luck!
Dec 23, 2010 | Marantz DV4100P DVD Player
My Panasonic DVD recorder DMR-E60 doe not respond to its remote control. IT display DVD 2!
Nov 24, 2009 | Panasonic DMR-E60 DVD Recorder
Pan DVD Recorder DMR-EH50
Press enter and 2 at the same time for more than 3secs
Oct 29, 2009 | Panasonic DMR-EH50 DVD Recorder
Remote not responding
Are you holding enter and channel number at the same time for about 2-5 seconds
Aug 05, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My DVD player has worked excellently for almost 10 years. Uncertain if that's the problem. All the buttons on the remote and on the front panel seem to respond--one way or another. This is a Sony CD/D
by a new player i recomend sony,there still the best. dont waste your money on blue ray,they will be obsolete in five years and they are very slow,ie. loading and reading discs, i know i sell them
May 19, 2009 | Televison & Video
Front display says "SAFE" and now nothing works
hold "info" button for ten seconds
Oct 02, 2008 | Samsung DVD-R135
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
