Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Copying does not give me a dark enough print. What do I do to get darker or more contrast?
  • csarosdy Sep 06, 2010
    I do not have the Cannon connected to the compujter, I am copy8ng manually. Anyway, I found the way to do it eith the buttons on the machine, and it is possible to get several gradations of darker.
  • 3,153 Answers
There is a setting in the softwaqre for this function BUT I tend to use a graphics package and these vary depending on your personal preference.
Even the microsoft photo editor has gamma correction and brightness contrast settings and you could use that to aquare the image and edit.
My preference is for a great piece of software called ACDSEE that has almost all you could need to quickly edit crop and manipulate pictures be they from a camera or scanner
Posted on Sep 08, 2010
  • Project NOMAD
    Project NOMAD Sep 09, 2010
    The settings for this are in the printer softare itself.
    You can adjust it to suit your taste from there.
    call up the printer utility or access it via printer properties.
    Bob
    Top Expert:
  • Canon Master
  • 78,919 Answers
Open the "Printer Properties" page (click the printer icon in bottom tray) and in the lower left of the preferences page you will see
"Print Quality" select "High", this will intensify the printing, it is the only adjustment for making the image or dialog darker/clearer. I own this same printer so am very sure of this.
Posted on Sep 05, 2010
Pc921 copies are light despite setting and plenty of ink
May need the optics cleaned or a new cartridge or both.
Feb 18, 2015 | Canon PC-920 Black and White Copier
Need to have the print darker! /Zebra QL420Plus/ How can I set the darkness?
zgorbe723: The darkness is only setup via software. Adjust it in your Windows driver or including the heat command in your format:
CONTRAST n 'in CPL comtec syntax
^MD+n 'in ZPL zebra syntax
Roberto Martinez
padrino99@prodigy.net.mx
Aug 31, 2011 | Zebra QL 420 Plus Thermal Label Printer
Lost my user's guide need to change make copies darker
May I know the model # of your machine?
Some of brother machine have the copy options where you can change the brightness, contrast and color of the document that you are copying.
For example for MFC-240:
You can change the brightness contrast by pressing copy mode. Then load the document in the feeder, press copy option so that it will show the option to change the brightness, contrast and color. Just press the arrow key to select the brightness then hit ok/menu. then press arrow key to have it lighter/darker..
Hope this helps.
Mar 29, 2011 | Brother Office Equipment & Supplies
Print is to light. How do I get it to print darker
there is a option u can do it dark and light,,,
press dark or light botton, than its gives u dark print ,,
if there is ok than change your cartridge,
May 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Typewriter is not printing dark enough. Is there
Many SCM typewriters have an impression control knob on them. Look for a knob on either the right or left side of the the keyboard with numbers from 1 to 10. The higher the number reading the darker it is supposed to print. Be careful not to go so high that the typeface cut holes in the paper. If this doesn't help, try putting a drop or two of sewing machine oil (or Triflow Oil) on your finger and rubbing it across the typebar segment (the slotted and curved metal piece that the typebars pivot in). Since the typewriter sat a while the segment may be sticky. Hope this helps.
Aug 25, 2009 | Smith Corona Office Equipment & Supplies
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Improving bar code image DPI for a darker output
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
Jun 12, 2008 | Datamax DMX I-4206 Printer
Images go suddenly darker
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
Jan 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
150 people viewed this question
old marine
old marine
