Question about GE Microwave Ovens
Our GE PROFILE JVM3670SK02 microwave stopped working. When you turn it on it only works for approx 30 sec and shuts off and the clock works but doesn't hold real time. Do you know what I need to do?
I HAVE THE SAME MICROWAVE. tHE ONLY TIME IT WILL HEAT IS WHEN THE FAN IS ON. ANY SUGGESTIONS
Posted on Oct 14, 2012
  • 3 Answers
I have the same model and my problem is that after I cook something and clsoe the door, the microwave stays on, carosel not turning fan is blowing and light is on. Repairman told me that I am not closing the door correctly and that is the problem. He tshowed me how the door is not solid and you can close the bototm part of the door (latching it) but not the top and that is why it is staying on. I say it is a manufacturer's design defect. He charged me the $99.95 service charge. What a rip off.
Posted on Sep 07, 2010
My GE OTR Microwave Model # JVM3670SK02 overheated when I tried to cook rice for 30 minutes...two times in a row. What could be the problem?
why are you cooking rice for 30 minutes in a microwave????? the problem is that a microwave IS NOT A RICE COOKER!!!use a rice cooker or use instant rice and heat the water for 2 1/2 minutes only!! OR BURN DOWN YOUR HOUSE!!
May 08, 2015 | GE Microwave Ovens
My GE Profile JVM3670SK02 microwave stopped heating. Can it be fixed?
Anything can be fixed, it all depends on how much it will cost to repair. Sometimes it just pays to buy another microwave oven they have come down in price quite a bit
Good luck
Feb 27, 2014 | GE Microwave Ovens
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
Microwave stop working
my microwave oven just stopped heating giving me a f9 error .lights are on clock is working and the panel is ok.
Jun 15, 2010 | GE Profile Spacemaker Over-the-Range...
GE Microwave power will not shut off
You will need to replace the control panel, better off to just replace the oven.
Aug 18, 2017 | GE Microwave Ovens
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
240 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
