Question about Dryers
2003 whirlpool dryer problems
This 2003 whirlpool dryer makes a loud buzz noise when i try to turn it on almost like the the drum belt is broken and causing the drum not to spin. Could you please let me know what kind of belt to get and a rough idea how long it takes to replace the belt for a first timer. THANKS!
NOTE* the model number couldn't be located.
    President:
  • Dryers Master
  • 2,651 Answers
Full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
Posted on May 13, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Whirlpool dryer was making loud squeaking noise. Now it is not turning at all. Makes a noise when you turn it on, but stops completely.
Check the drum belt. Check the drum rollers on the back & glides on the front that the drum rides on also check the idler pully. Check the felt the drum rides on in case it came loose and won't let the drum turn. Did it hum when you started it if so could be the motor. Good luck
Apr 06, 2014 | Whirlpool GGW9200L Gas Dryer
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Dryer stopped working
The clicking noise is probably the timer switch working ok...no problem there
Sounds like you could have a broken belt, that will keep your drum from turning.
If you have a front load machine, remove the front, that will expose the drum. You should see the belt on the drum, if it is not there then it is broken.
You would then remove the drum and replace the belt, while your at it you should go ahead and lube the drum rollers at the shaft with a good grade of machine oil...Like 3 in One oil...it will extend the life of the rollers and help to keep them from making noises later.
I hope this helps
Oct 02, 2009 | Whirlpool LER4634J Electric Dryer
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
172 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
