My kenmore stackable washer model 417.92702200 washes the cothes and drain but not spin. The clothes are very wet and smell burned when it try to spin.
    President:
  • 3,773 Answers
This involves the spin lid switch.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 05, 2010
Kenmore stackable washer will not drain burning smell
THE DRIVE BELT HAS BURNT UP AND NEEDS REPLACED
Aug 14, 2014 | Kenmore Washing Machines
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
My Kenmore Elite washer needs help. My cothes still come out dripping water after the spin cycle stops. Does this sound like something major ?
not normally this is usually casued by a resrtiction in the driam pumo area.if you check and clear all the hoses to the drain pump this should help with the spinning out of the clothes
Nov 14, 2010 | Kenmore Elite HE5t Washer
Washing machine shake &makes noise on spin,water doesn't drain completely out.Cothing are still wet
Don't know what type of washing machine you have since you did not provide a model number. But if it is a front loader, and it makes a loud noise when spinning, the problem could be that the support arms have failed. It would cause the machine not to be able to spin properly. To confirm the problem, unload the washer. Spin the wash drum by hand, and notice if the drum sags or wobbles when it spins. If it does not turn smoothly, then chances are the spider arms are broken. It is big job and expensive to fix. Get a few estimates before deciding whether it worth fixing.
Oct 05, 2010 | Maytag Washing Machines
My kenmore top load washer works well, however when the spin cycle runs...the water drains but the clothes are still soaked. It sounds like it is spinning (but Im not sure if it actually is) and there is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
