Question about Brother Sewing Machines
How do I thread a bobbin on a Brother LS-2125 sewing machine?
    Genius:
  • 1,788 Answers
Go to brother-usa.com and download a manual for free, it will show you everything you need to know
Posted on Sep 12, 2010
SewTechWayne
  • 186 Answers
SOURCE: bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Posted on Jan 29, 2009
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
WonderTech
  • 268 Answers
SOURCE: I have a Brother LS-2125 and when I try to sew it
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Posted on Dec 30, 2009
  • 1116 Answers
SOURCE: Need threading instructions for brother sewing
Brother has a website where you can download a free manual.
Posted on Feb 20, 2010
  • 1788 Answers
SOURCE: Can I have a FULL tutorial video on how to thread
I do not think that they make a video for your model. You can download a copy of your manual for free, at www.brother-usa.com and then you can enlarge the diagrams. Save it on your computer then you always have a copy. You can also print it out. Your machine is very basic and you will be a pro in no time. Just take your time, relax and be patient with yourself.
Posted on Oct 11, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
I have a brother LS-2125 and the thread from the bobbin is not catching and is not being pulled through.PLEASE HELP! i need it for an assignment! :)
Here are some things that may fix the problem:
1. First, replace the needle
2. Next, remove the thread and completely rethread the machine
3. Remove the bobbin, clean any lint or thread from around the bobbin, and replace it.
Try sewing again on scrap fabric.
I hope this helps.
Apr 01, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a LS-2125 brother machine, and when I sew the thread from the bottom catches and breaks. I have taken the bobbin casing apart and cleaned and oiled it, changed bobbins, tried to adjust the...
make sure that it is threaded right, and that you do not have your needle inserted backwards, flat side should face rear of machine, read your manual carefully. If you do not have one, go to www.brother-usa.com and you download one for free.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Bobbin
Sounds like thread is caught in the shuttle. Check your owners manual, if you misplaced it, go to brother.com and download it or print it for free
Jul 23, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have this machine brother ls-2125.my
You need to either adjust the tension or ensure that you have routed the bobbin thread properly.
Apr 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
I have a brother ps57 sewing machine
MY PROBLEM IS NOT WITH LS-2125 MECH SEWING MACHINE
Jul 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125 how to thread bobbin
all manuals for a brother sewing machine are downloadable at www.brother-usa.com
Apr 02, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125
ple let me know LS-2125 what option its have
Feb 15, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
