Question about Altec Lansing ATP 3W Computer Speakers
Broken right speaker
My 6 year old son pulled the right speaker (the one with the volume controls on it) and the wires pulled out. My husband tried to fix it but despite his efforts, not only does the right speaker not work, but neither the left speaker or subwoofer will work now. Any advice on hooking it up wothout the right speaker? Or maybe a diagram for rewiring the broken one? please help!
    New Friend:
I just inherited a ATP3 subwoofer only!
Does anyone know if I can run a left and a right speaker from a different manufacturer with my Altec subwoofer???
Posted on Dec 03, 2012
  • 3 Answers
The only way to fix,is to colour code them back together,or go spend some more $$$ on new ones....later
Posted on May 12, 2008
Dear Bethann240
It is very difficult to rewire the right speaker( the one with the controls). The black cable contains an orange and black pair which drive the "big" speaker in the base. The white wire has the wires for the controls. That white wire is .090 in in dia. Peel back the white pvc insulation and you will find a layer of aluminum foil which is intended to shield the control wires.Then there is another layer of insulation. Peel that insulation back and you find SIX color coded lacquer insulated wires. Each wire is .010 in in dia. If you attempt to solder the severed wires together you will doubtlessly melt the lacquer and short the cable out. Twisting the wires together without removing the lacquer won't work. The satellite speakers were intended to be non-repairable, thats why the case is glued together.
The best bet is throw the right speaker in the trash and try to purchase a replacement from Altec or find a replacement in a flea market etc.
Sorry
Elder1943
Posted on Jun 01, 2008
The radio plays full volume on right channel when turned on.
Anything I tell you is going to be a guess, since there has been no testing done, and we don't have the model number of the specific radio involved. However...
For a 20 year old radio, the volume and balance is almost certainly controlled by a potentiometer that has input into one leg of the fixed resistance, and the other leg (of the fixed resistance) is grounded. The movable center tap is the output to the amplifier - and its position controls the volume to that channel. If the ground leg becomes disconnected (broken wire, or a cold solder joint, or even a break in the resistor within the body of the potentiometer) then instead of "dividing" the volume, it simply provides a slight resistance inline - short answer: It goes full volume.
You can try running the control full range back and forth, and even just the old time "slap it" approach, to see if you get any static or change. If you do, that pretty well confirms the diagnosis. [If not, it just means the break is not close to touching - still almost certainly the right answer though.]
Only fix is going to be disassembly. You then may be able to find the break (and resolder it), and/or replace the volume potentiometer. Note that if you have remote volume/balance control (controls on the steering wheel), then there is some extra wiring that can likewise be involved. jk
Feb 27, 2015 | 1995 Jeep Grand Cherokee
Checked both speakers..no matter which i connect to right output speaker terminal.get static.speakers r fine. system is ten years old.
Right output transistor is fried, replace . Take old ones (both left and right) to radio shack for new replacements.Replace BOTH
Dec 07, 2009 | Adcom GFA-5300 2-Channel Amplifier
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
I'm going crazy. I have an I-Art 32", it's about six years old. We just bought it from a friend. The volume worked, then we were trying to program it and messed with buttons and no volume will come on! My...
check mute button on remote and on front of tv also check for speaker wires broken are chewed up are broken by animals are rodents are came loose
also go in to the menu ans make sure it is setup right
Feb 22, 2009 | JVC AV-27530 27" TV
Front left speaker is louder than the right one Replaced my altec lansing speakers because left speaker was louder than right. They were about 6 years old, replaced with Logitech 2300. Same problem. If I...
JUST ADJUST THE BALANCE IN THE VOLUME CONTROL, YOU CAN FIND IT IN THE CONTROL PANEL OR AN ICON AT THE BOTTOM RIGHT OF YOUR SCREEN, THE RIGHT NEXT TO THE CLOCK.. PLEASE VOTE FOR MY POST
Oct 29, 2008 | Audio Players & Recorders
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Broken screen?
the screen is 3 pieces...and need to be flat to one another..kids (husband and son) might have knocked them apart..just need to put the screen back together and put them back into the groove.
Jan 27, 2008 | Philips Magnavox 9P6034C 60" Rear...
Multimedia speakers not playing up to potential
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the excellent solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: <p> 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.<br>
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it.<br> 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up..<br> 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only. Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.<br>
5. Put the FR speaker box back together in reversed order.<br> 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again.<br>
<p> As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.<p>Thanks for giving the lead trickytrev34.
Jun 27, 2007 | Altec Lansing Multimedia Computer Speakers
Limited volume on speakers. Worked well previously.
Guys,
In case my nickname does not show, this is treefarmer. I had the same problem and decided to fix it myself over this Christmas. I was successful, and here is what I found.
In my case, the problem lies with the volume control chip ( it has a voltage controlled amplifier, or VCA in it) on the main amplifier board. The voltage which controls the volume for all channels comes from the right front speaker. There is an issue with the I.C., in that it has some abnormal loading (leakage) of the volume control signal at the I.C. pin. You need about 5.2 volts for full volume output, and on my system, I can only get about 1 volt. You can find the IC data sheet (Mitsubishi M51132L) here:
datasheet.html">http://www.datasheetarchive.com/M51132L-datasheet.html
The parts inside the enclosure get quite hot under normal operation, and I would not be surprised if this I.C. has an issue with degradation under high temperature. Regardless of the problem, I managed to get the volume back with one simple fix.
If you can open up the right front speaker, place a 10 kohm resistor in parallel with R1, which should have three orange stripes, and one gold stripe. This fixed mine, but this might only be temporary, depending on how much worse the volume control I.C. becomes.
I did check out the power supply, including transformers and everything else, and they all look fine. It would surprise me if the transformer failed as has been posted in other forums. They should be able to survive higher temperatures than the other electronic components in the box, especially when most of them are consumer grade parts with a max temperature of 70 C. One thing of note is that turning off the right front speaker pretty much shuts off most of the quiescent current draw of the amplifier board. I found that with only the sub cabinet switch on, nothing gets warm. You won't see significant warming of the interior components until you turn on the right front speaker. However, then the inside of the sub enclosure gets pretty hot (too hot in my opinion) just sitting there with all the speakers powered up.
I would recommend at least turning off the Right Front speaker when the computer is powered down. More often if you are not listening to anything. I don't think you need to shut off the sub enclosure to keep things cool, but turning off everything ensures that the amp is not sitting there cooking itself. And, unless Altec has changed the design, I would bet new systems will fail in the same manner.
For what that's worth. Hopefully somebody will find this helpful
TF
Dec 01, 2006 | Dell ADA745 Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
628 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
