Question about Monster Cable DS500-CL-EZ1000 Dataspeed 500 CL Cat 6 EZ-pull box - 1000 Ft. Spool (#ds500-cl-ez1000)
Masterpiece cable box descrambler
My cable box worked perfectly and now my channels will not come in and a smiall u then the number appears where you would see the channel on the window.
Thankk you
Lisa
Problems with Monster Cable DS500-CL-EZ1000 Dataspeed 500 CL Cat 6 EZ-pull box - 1000 Ft....? please price
Posted on Jul 09, 2008
Problem with audio and vidio
Is this a problem only with the cable box or also with oother sources as well?
Feb 03, 2008 | Pioneer PDP-6100HD 61 in. Plasma...
Hi fixya I don't have card in PCMCIA slot am told it is not important, I am only watching free view channels not subscription channels all the channels are programmed onto the TV. When TV is connected to...
You don't mention the make or model of your TV, so I am having to take a few educated guesses here: I think you need the common interface module on the TV if it's not going through another receiver. The CIM basically is the thing that allows the broadcast signal to be decoded (free or not). The SkyBox has it's own card and is already doing the descrambling first and then just sends the signal on to your TV.
I am not sure what the "free view box" is that you are using, but it sounds like it doesn't have a decoder.
May 28, 2014 | Televison & Video
I have an RCA F31672ET and it works perfectly on channels 51 to 98 but will not recognize the rest of the spectrum. I am on cable. Thanks.
Depends on how your cable provider is distributing the TV channels.
Channel 100 is the line into the Jumboband, and most providers don't distribute analog cable beyond channel 99 since it requires a different type of amplifier. They will generally use Digital Cable for higher number channels, which would require a converter box.
http://en.wikipedia.org/wiki/North_American_cable_television_frequencies
Who is your cable provider?
Apr 24, 2011 | RCA F31672ET TV
HDTV with descrambler, I need a channel lineup for all channels without a cable box for Suddenlink cable in Bossier City, LA (the digital numbers like 17-2...etc). I have many channels now, but need a list...
I discovered last year what you just recently discovered. Cable TV providers transmit digital signals over cable using what is known as a QAM signal. Most new TVs (but not all) are equipped with a QAM tuner (check your owners manual in the specs section). Your cable company sounds like a kinder more humane provider, just like mine. There are no federal regulations regarding what cable companies can or cannot do with QAM transmission. Most of the big providers such as Comcast scramble most or all of these signals, forcing the customer to pay extra for cable box rental. But some of the smaller providers allow all of their basic tier, non-premium channels to be transmitted freely, meaning that if you are not interested in PPV or premium channels, you don’t need a cable box. My cable provider (Service Electric Cable TV of Lehigh Valley, PA) initially did not print any QAM channel line up, so I went through each one, wrote them down, and created an Excel Spreadsheet so I had my own printed line up, which turned out to be a good idea, because my carrier has made several changes over the past year in their line up. Later, they did post a line up on their web site, but promptly made more changes without updating the line up so my advice to you is to create your own.
Jan 17, 2010 | LG Televison & Video
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
Vertical red lines apear on Sony XBR after Roku install
try re-botting your HDbox,also refit your scart lead to your box & t.v.
If you drop me an e-mail I will go through how to re-bot your box,if you don't know - re-botting your box helps pull in all the new software for your box - think it like a pc needing to update the programmes.
e-mail add.pbviewingsky@yahoo.ie.
Aug 07, 2009 | Televison & Video
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Hook up
Contact ur ISP, tell them to turn off interleaving
Interleaving definition: Where consecutive bits are interleaved amongst other bits in the bit-stream over a certain period of time to improve ruggedness of data., A process of scrambling the order of symbols to be transmitted over a channel in such a way that, when they are descrambled (at the receiver), any burst of channel errors will be spread out in time and thus appear as random errors to the decoder.A process of scrambling the order of symbols to be transmitted over a channel in such a way that, when they are descrambled (at the receiver), any burst of channel errors will be spread out in time and thus appear as random errors to the decoder.
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
How do I get my local channels from my VCR.
If you have a cable or satellite converter all inputs are converted to channel 3 or 4. If your vcr is attached to this output you will only get whatever the converter is tuned to. If you have cable, try connecting the cable that's now on the input to the converter to the input of the vcr and then add the channels automatically. However, the converter also descrambles premium channels, so you cannot get them into the vcr without going through the converter first, and some digital cable channels will not work on all vcrs. If you use the converter, always leave the vcr on channel 3 or 4 or use the converter video/audio outputs. You will not be able to record one channel and watch another without some additional hardware including an rf switch, rf splitter, and more cables.
Dec 04, 2007 | Zenith VCS442 VHS VCR
Monster Cable DS500-CL-EZ1000 Dataspeed 500 CL Cat 6 EZ-pull box - 1000 Ft. Spool (#ds500-cl-ez1000) Logo
133 people viewed this question
Top Monster Cable Computers & Internet Experts
David Payne
David Payne
Are you a Monster Cable Computer and Internet Expert? Answer questions, earn points and help others
