Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
I have kenmore C978-70805-1 refrigerator freezer work ok but refrigerator stop working . i check the low and high button .i can hear the fan sound because when i tun off it stop . it means thermoste switch is working fine but i don't know what is the problem i'm handy man i know if i figure out what is the problem i can fix it and save some money . realy appriciate if you can help. or if i can find manual. thanks. HR.
    President:
  • 3,773 Answers
Sounds like a defrost problem. remove back freezer panel and look for ice on coils which restricts air to the Ref.
Take your mod number to an appliance parts store and they will sell the parts to fix the defrost system. Most all parts are in behind freezer Panel at the coils.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 05, 2010
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
Both refrigerator and freezer have stopped cooling. The compressor sounds like it is working and then will stop. The fan is working. The copper pipes coming from the compressor are hot/warm to the...
This sounds like your refrigeration unit is low on charge...there probably is a leak in the system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Not cold and freezer is not frozen, but fan is running
dear sir/madam
i think your freezer,s compressor is not working so try to hear comressor working sound if it,s working then there is low gas problem, try to contect your service technician for refill freon .
hope answer the question
thank you
please vote!
Jul 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Its not getting cold
MAKE SURE THE FANS ARE RUNNING FREEZER AND COMPRESSOR, THEN CHECK THE BACK WALL OF THE FREEZER IF ITS FROSTED UP YOU HAVE A DEFROST ISSUE. IF THE COMPRESSOR AND FANS ARE WORKING AND NO FROST IN THE FREEZER THATS NOT A GOOD THING..
Jan 13, 2010 | Kenmore 74852 / 74854 / 74859 Top Freezer...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Refrigerator stoped cooling
Ok, if the unit compressor will not run and just clicks on and then off, this will confirm a low charge state ad you will need to recharge this unit. the refrigerant level is low.
Purchasing a recharge kit and recharging the system will fix this issue.
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer stopped freezing up?
check the compressor to see if it works. You should hear a sound that sounds like a low hum.
Is the compressor fan on at the bottom rear of frig?
Apr 09, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
i think you will find fan has stopped working - take back plate off inside freezer and check fan goes and that pipework is not iced up
Sep 10, 2008 | Kenmore Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
326 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
