Question about Cambridge Soundworks Newton Series T500 Speaker
One of my cambridge speakers (gateway) makes fluttering sounds whenever the speakers are turned on. How do I stop this irritating noise?
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
Woofer has popping noise
I have the same problem with my Cambridge Soundworks CSW250. Also one of the speakers doesn't work all the time. I'm sure it's a loose connection on the circuit board. When I tap the subwoofer near the connections, the popping noise changes (gets worse, better, other speaker works,etc.).I tried taking the subwoofer apart, but the area near the connections is sealed with glue, so I cannot access it. I hate it because when it works,it sounds so good. Anyone know how to get just the circuit board and back panel?
Aug 09, 2012 | Cambridge Soundworks Audio Players &...
Had my computer rebuilt and now my cambridge soundworks GCS300 speakers will not work....what do i do
Generally speakers will not need a driver, its more likely your soundcard needs the driver - have you tried anything else rather than the speakers to get sound? If you cant get any sound at all then its your soundcard so you will need the driver for it - otherwise try the link below, its the only thing that comes remotely close to a driver for these speakers -
http://www.bioticaindia.com/gcs300.html
thx, hope this helps :)
Jan 28, 2011 | Gateway Cambridge SoundWorks GCS 300 PC...
(Dv6000) Sorta frequent loud popping noise.
This happened with a DV9000 recently and the speaker assembly had to be replaced. I found one on ebay for 5 bucks. Need to remove the power button plate and unscrew the speaker assemblies and replace.
Jul 22, 2009 | Gateway GMAX 2100 Computer Speakers
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Flutterin sound in tv
try turning the bass down and see if this helps the fluttering. If it does help a little most likely it is a blown speaker. Can replace at radioshack for under 20 dollars. It is hard for me to tell since i am not there to diagnose but also can you do a balace to go completely to the right with bass up and see how it sounds. now with bass up turn the balance to go to left speakers. if you hear fluttering from one side that means a speaker or speakers from the side that is fluttering need to be replaced. i hope this helps and good luck fixing this.
Feb 21, 2009 | RCA Televison & Video
Iball speakers making irritating noise
please try better speakers better ohms orhigher wattage. improper speakers not for pc's or laptop will cause the hum..
Nov 29, 2008 | Audio Players & Recorders
Noise
That is a factory defect problem,i encountered like your problem before,it is a brand new also there is a hizzing sound a like.I told him send it from it you bought, then the problem is solve...
hope may this help;
Jul 18, 2008 | Cambridge Audio Azur 640P Amplifier
Cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Dec 24, 2007 | Gateway Edison Computer Speakers
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
Cambridge Soundworks Newton Series T500 Speaker Logo
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
