Question about Coleman Camping, Backpacking & Hiking
How do you open the battery compartment of the coleman series 5339 flashlight/lantern? Thanks
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
dcramer531
  • 1654 Answers
SOURCE: How do you change the batteries on a Coleman
All The info I can find nothing tells us how to change the batteries. Is this a rechargable light, if so the batteries are not available for replacement. If not then the top has to screw off, or the bottom plate must screw off, there isn't any other way. What I have read is that these on this light are very hard to remove, at least that is what folks are complaining about. this light has also been discontinued and no longer availabe. if your afraid of breaking the light then I would contact Coleman for their advice since there seems to be none to be found on any bulletins they have put out.
Posted on Apr 28, 2011
kelsey146588
  • 4 Answers
SOURCE: Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Posted on Jun 07, 2012
ka4iup
  • 3960 Answers
SOURCE: How do I open the battery compartment on Eddie Bauer flashlight and lantern
https://www.youtube.com/watch?v=ufv4umQzClU @ 2 minutes.
Posted on Mar 08, 2015
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Nov 22, 2011 | Camping, Backpacking & Hiking
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Jul 20, 2010 | Coleman Camping, Backpacking & Hiking
Cant figure out how to take apart to replace bulb
More information is required in order to answer your question. However, the following link will take you to the Coleman website for battery powered lanterns. www.coleman.com/coleman/parts/product_category2.asp?category_id=170
Jul 19, 2010 | Coleman Rugged Battery Powered Lantern...
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Camping, Backpacking & Hiking Logo
194 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
weirdtop
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
