Question about Ovens
Self cleaning oven
The door on my self cleaning oven when I run the oven to clean it. Does not clean. Can I use easy off spray on it to clean it?
  • 117 Answers
You can use a razor blade with easy off
Posted on May 13, 2008
My oven is saying unlock door after self cleaning but the door is open
It's likely that the door switch has failed, or stuck in the depressed position from grease or your oven cleaner spray solution. To correct this problem, remove the door switch and inspect with a multimeter for continuity connection.
Dec 22, 2013 | Ovens
My husband sprayed the non-fume Easy-Off oven spray into our KitchenAid self-cleaning oven. Then turned IT ON TO CLEAN! It was on for about 1/2 hour. There are instructions all over the can NOT to turn...
The best thing to do is with a cold oven, go ahead and use the Easy-Off non fume again and wait 2 hours. This should remove the original grease as well as the left over Easy Off from the 1st application.
Jun 05, 2011 | Ovens
When I try to start the self-cleaning oven, ''door'' appears in the display, and then the display goes to F5 E1. The door doesn't even try to lock. I have a Whirlpool Self-cleaning electric range Model #...
there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How to self clean oven
If it has a self clean feature, you can set that feature to self clean. If it does not, you can use Easy Off oven cleaner. You should turn the breaker off to the oven first. Lay newspaper on the floor around the oven to catch drips and spray the entire oven. Let it sit for a few hours and use your vent hood to elimnate fumes, then wipe out with an old cloth. Hope this helps and answers your question. Ella
Aug 18, 2009 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Aft self-cleaning, top of oven door and knob panel discolored
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning better than self-cleaning
What you have read is correct, the catalytic lining can be damaged by corrosive sprays. It should be safe to use 'Easy Off ' on glass though.
The standard Auto clean cycle is the best method of cleaning that i know of.
Nov 29, 2008 | GE JTP86 Electric Double Oven
Dirty self cleaning oven
easy off has a new spray for self cleaning ovens start with that after getting loose grime then self clean
Oct 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning
Never use spray cleaners in a self clean oven it will void your warranty and possibly ruin the oven. it sounds like what may have happened is the fumes from the spray ignited inside the oven and may have blown out the pilot light if your using gas.
or maybe replace the thermocouple. sorry, hope that helps.
Aug 03, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
Ovens Logo
82 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
