Question about Vacuums
Belt Replacement How do you change/replace the belt on a Hoover Dimension Supreme vacuum?
    President:
  • 1,673 Answers
Take the bottom plate off, the brush roll and belt are there. the belt goes around the brush roll and hooks to the motor shaft. If you can't get to the motor shaft, then you will nee to remove the top cover also.
Posted on May 13, 2008
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
What is the code number of the replacement sacks for the
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=U5227-930+Elite+Upright+Vacuum+Bags
Jim
Nov 28, 2009 | Hoover U5227-930 Elite Upright Vacuum
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
The belt needs replacing
Here is the manual to your Hoover U6630
www.thinkvacuums.com/pdf/uprights/Hoover_U6630.pdf
it goes into detail on how to change the belt and which belt to purchase. Ask for a flat belt Hoover part No. 38528035 when you're going to purchase the replacement belt
Aug 31, 2009 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Need a replacemnet belt for upright hoover durabrand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723179
Need a replacement belt for
Posted by madasalorry on Jun 30, 2008
Need a replacement belt for upright Hoover durabrand
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get a replacement belt for a Hoover DuraBrand vacuum is to contact your local vacuum cleaner dealer in your area or to contact the factory @ Hoover listed below and call cust serv and they will direct you to the parts dept. but, please use the genuine belts instead of replacement belts and the average belt change for flat belts is every 4 to 6 months and if it is a geared belt than once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 03, 2008 | Vacuums
Vacuums Logo
272 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
