Question about LG 22 Cu. Ft. French Door Refrigerator, LRFC22750
My left door won't stay closed. It appears that a part is missing in the top left corner of the left door. Looking for replacement part number and installation directions. Is this the left hinge cam?
3 Suggested Answers
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
MNTECH
  • 1543 Answers
SOURCE: I have a LG side-by-side Model LRFD25850ST - the
The insulation is all foamed in place. Doors can not be dissassembled, other than replacing gaskets.
Posted on Mar 06, 2011
How do I replace the door latch?
A good place to view exploded parts diagrams is Sears Parts. See http://www.searspartsdirect.com/samsung-refrigerator-parts/model-RFG297AARSXAA0000/1482/0161000.html. Note that the parts you are looking for could be in the left door diagram or mor likely the cabinet diagram.
Aug 05, 2015 | Samsung RFG297AARS (285 cu ft) Bottom...
GE under oven drawer sags, won t close properly, big gap exists between drawer face and oven door.
Don't look too hard for a solution to the problem. I have seen this same issue with three or four other manufacturers brand stoves. Not sure why they can't build a drawer that won't bind and stick, but they seemingly cannot.
Jan 06, 2015 | GE Stove/Oven/RanWhite Glass Top -...
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Damper won't close
Depending on the correct model number found inside the fresh food section will help diagnose but it sounds like either a defective temperature sensor or the damper itself is the cause. If your model number is a USA model number I can look up what part number and tell you better by looking at parts manual. Let me know the model number and I will try to help you find the correct parts, Thanks Sea Breeze
Sep 15, 2012 | Electrolux Refrigerators
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Purchased a used Monogram Dishwasher/no factory info was included
First, here are some tips to help with your model number: look for an aluminum tag--or a silver or white adhesive label. The model number may be printed or stamped onto the tag and it may be written in two different type sizes or styles. You might find the tag in one of these places:
  • Inside the door jamb, to the left, right, or top
  • On the door, to the left, right or top
Feb 12, 2009 | GE 24 in. Monogram ZBD6880KSS Stainless...
Garage door won't stay closed
Check the down limit:
 If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing  the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing  the garage door)
Jan 03, 2009 | Electrical Supplies
LG 22 Cu. Ft. French Door Refrigerator, LRFC22750 Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
