Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Battery reads full on the charger but mower acts like battery is dead and won't start
    President:
  • 1,033 Answers
It may show a full charge but when you go to turn the engine over it's draining the charge and there's not enough of cranking amps to keep it turning over. I would suggest installing at least a 350 cranking amps. This will not hurt the engine but it will give more power to turn the engine over to start. A lot of cheaper batteries are only 200-275 amps but don't last long.
Posted on Sep 05, 2010
Vehicle acts like dead battery but it is not.
It is a type of security system. Like you said all functions are turned off until you push button because battery is disconnected from system.
Apr 28, 2016 | Cars & Trucks
My 98 blazer acts like the battery is dead but when i hooked it to a battery charger it said it was full and running at 9.1 when it should be running at around 12 then said error f03. so what does that...
It means the battery charger is your problem. Find an old-style simple battery charger, not one of these new "smart" chargers. The simple ones allowed YOU to decide whether to charge or not. Placed more responsibility on you, but a simple charger would WORK for your battery.
At 9.1V, your battery's DEAD.
Jul 12, 2014 | Vector Black And Decker High Frequency...
My 2008 dodge caliber acts like I have a dead battery but when you jump the car or put a nbattery charger on the car will start. The battery charger when you put it on the battery reads that the battery is...
Susan, this sounds like a "cold" connection. verify that all connections are clean and tight, especially at the battery. Grounds are suspect.
Jul 09, 2014 | Cars & Trucks
Tried charging john deere battery no good after 4hrs.whats up
Walt
Does this mower have a Briggs and Stratton engine with overhead valves? If so, (and this will sound really weird) you need to adjust the valves. After a few hours of running, the intake valve will go out of adjustment so the decompressor won't work. It acts like the battery is dead when this occurs.
Mar 24, 2014 | Garden
Mower won't start
make sure your cut off switch aint stuck
Jun 30, 2012 | John Deere Garden
Cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Jun 09, 2012 | Cub Cadet Garden
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Car wont start, acts like battery is dead. battery shows full charge. full lights, buzzers, etc. put it on charger-didnt start...cleaned cable connections-didnt start...tried to jump with truck-didnt...
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Oct 10, 2009 | 1993 Ford Tempo
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
217 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
