Question about Canon PIXMA iP90 Mobile Printer
Canon ip90 printer wont grab paper
The paper wont go through printer...seems unable to gain purchase.
  • DeniseMarie May 12, 2008
    My paper won't feed in and I get an error message that there is a paper jam. Please Help! I tried open up the printer but the thing won't open up all the way.
  • mgfin May 13, 2008
    it sounds good, but didn't fix the problem...
    Novelist:
  • 105 Answers
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
Posted on May 12, 2008
  • odiornej Jan 28, 2011
    Good advice, but did not help. Mine feeds from the right side. Cleaning like this made no difference to my problem. This is a nearly new printer, disappointing.
Canon ip90 will not take paper through the printer
I have had similar problems with Canon and Epson printers. Standard solutions are not earth shaking, but worth a try. Use paper heavier than 20 lb, get a roller cleaner paper from the manufacturer
and run it through to clean the rollers.
Jun 04, 2014 | Canon PIXMA iP90 Mobile Printer
My Canon IP90 printer in printing blank paper
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaces.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new injet printer.
Jan 16, 2011 | Canon PIXMA iP90 InkJet Printer
My canon ip90 wont print anything
Good day!Kindly check if your printer is still running..check paper..inks..drivers...see if it is your default printer..
regards..
mastergani
Mar 29, 2010 | Canon PIXMA iP90 Mobile Printer
Canon ip90: paper won't pull through rollers. Rollers are turning and nothing seems to be lodged in printer. The case is not bent in any way.
It's a plastic case and you can't see without removing covers. If it's been packed in luggage, any weight put on top it can bend and you can't see it from the outside. When the top is bent you might see from the front, but sometimes the bottom gets bent upward which also stops paper from going thru. The covers are plastic and return to normal shape after bending the inside parts.
Feb 05, 2010 | Canon PIXMA iP90 Mobile Printer
Paper will not start feed in on it own
Probably no paper jam, but put a ruler across the top across where the switches are, if it's bowed down some the frame has been bent. Any weight, luggage,etc placed on top can bend the frame and that restricts the paper path and you need a shop repair.
Jan 08, 2010 | Canon PIXMA iP90 Mobile Printer
My Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
My paper won't go through my canon ip90v straight
You may need to clean the pickup rollers. These are the ones that pull the paper out of the tray and begin feeding them into the printer. It is likely that one side may be slighly gummy and the paper is sticking to it or the other side may be slick with miniscule paper particles that is causing it to slide right over the paper surface and not grabbing it at all.
Apr 07, 2009 | Canon PIXMA iP90 Mobile Printer
Wont scan from adf. also bends corner of paper when printing
f your printer is unable to pick up paper and the feed rollers are turning, remove the rear access door and clean them with a cloth moistened with water.
Jan 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper in printer
Goto the link provided below. You will need to fill in the three drop down windows.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Select cateegory = Printers
Select product type = PIXMA iP Series
Select model = PIXMA iP90
Click GO
Start with Number,
1.) Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Continue down till issue is resolved.
Feb 12, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
723 people viewed this question
old marine
old marine
