Question about ViewSonic N2635w 26 in. LCD Television
I have a viewsonic N2635W and it is stuck in Standby mode - not sure if it was because of an errant hit on my remote but it powers on for about 3 seconds (blue light) then it goes back into standby mode any suggestions? PS - changed power cord already
KaeZoo
  • 156 Answers
SOURCE: Flashing PROTECT
This is often caused by a problem with the speakers or speaker wiring. A speaker wire that's pinched behind the head unit will cause this problem if it's shorted to dash metal or the deck chassis. The first thing to do is remove the head unit and inspect all the speaker wiring for bare spots or pinched spots. If everything looks okay, disconnect all four speakers from the deck and switch it on. If it still shows "protect" then you have a defective head unit. If not, then turn it off, re-connect one of the speakers, and turn it on again. Continue until you find the speaker output that puts the deck into protect mode.
Posted on Jun 26, 2007
  • 56 Answers
SOURCE: DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
SOURCE: stuck on standby
sticks on standby
Posted on Jun 10, 2008
ginko
  • 19396 Answers
SOURCE: tv has got stuck on standby mode
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
  • 23 Answers
SOURCE: TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Posted on Jul 04, 2009
Sony Bravia stuck on Bravia screen
"Bravia Screen". Not sure what you mean. Is it in maintenance mode?
Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
DISPLAY - 5 - VOLUME + TV POWER.
When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
Hope this helps
Mar 10, 2013 | Televison & Video
Need new remote
Try website like Remotes.com to buy an exact remote to the original remote.
Oct 30, 2010 | ViewSonic N2635w 26 in. LCD Television
N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
May 10, 2010 | ViewSonic N2635w 26 in. LCD Television
Will it work on viewsonic
To control a Viewsonic TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the four-digit code 1755.
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 24, 2009 | One For All URC-3021 Remote Control
Viewsonic n2635w 26 in tv's turns on button dosn't work.it looks like power supply is gone. please help me.
If you do not want to trouble shoot the problem down to component level in the power supply, you will be better off buying the replacement here: http://www.shopjimmy.com/catalogsearch/result/index/?q=ViewSonic+N2635w+&stock=all
Check to make sure you do have 5vdc, 12vdc, 24vdc before ordering the new part you do not need.
Please post back what you find.
Dec 24, 2009 | ViewSonic N2635w 26 in. LCD Television
My N2635w 26 in. LCD Television is set to VGA, and won't change
you will need to temp hook up to w pc to get a signal into it then change it I hate that when that happens
Nov 30, 2009 | ViewSonic N2635w 26 in. LCD Television
I have a ViewSonic N2635w LCD TV and the picture looks so stretched out width wise. I don't see anyway to fix the picture with the remote. How can I change the picture to look normal?
there should be something in the menu where you adjust things. seems as your in wide mode or zoom mode. should be something there to adjust the picture.
Jun 10, 2009 | ViewSonic N3735W 37 in. LCD TV
ViewSonic N2635w 26 in. LCD Television Logo
135 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
